JR’s Mk2 Capri
JR
I need some advice.
How do I un fuck this..
When I put the V8 in I was very short of realestate and cut out the radiator mounts.
Ideally I would like some factory looking mounts to go back in.
Something like this.
Problem is, I'm a shit fabricator. If I could find replacement panels I'd happily do that but I can't find any.
Any ideas?
Cheers.
She goes 100mph just sitting there. Pretty stoked. I picked the engine up a few days ago, the guys at Kennally Cams did a brilliant job. I've just been putting the shiny parts on.
The bellhousing and clutch kit arrived from Dellow Conversions. On the whole I'm happy with it. The bellhousing is perfect, but I'm a bit worried about the clutch assembly  they supplied and would appreciate any input.
They supplied a kit to mate the engine to a w57. Pressure plate, clutch, slave cylinder, bellhousing etc.
They modified the pressure plate that they supplied. The original ford pressure plate has 6 bolt holes plus 3 holes for dowels that are on the fly wheel.
The one they supplied has 6 holes total. 3 line up with bolt holes and the other 3 have been drilled out by them where the dowels go.. But over sized so the dowels no longer locate the pressure plate.
That is one of the holes they drilled out.
This is it sitting on the fly wheel.
I have just had the engine balanced. My concern is that without the locating dowels (they are useless as the holes are now too big) the 3 bolts alone won't locate the pressure plate exactly in the center necessarily.
They guys that built the engine don't think it's a good idea to run as is. What are your guys thoughts?
I queried Dellow, and they said yeah, nah, it's sweet.
Also, the front cut for the radiator suport panels seems to have fallen through. I think the dude literally died. No answer to calls, txt or email. And the shop (kiwi auto) is chained closed.
Cheers for any input!
John.
  • Like 8
  • 2 months later...
