Popular Post 30DegreesRetarded Posted April 25, 2023 Popular Post Posted April 25, 2023 1975 Datsun 260c H330 wagon goodness. I purchased this wagon from Tauranga and shipped it to the South Island. I put the original suspension back in and took it for a WOF. ride height made it a boat but at least I was out driving. 3 speed auto is awesome to drive on the roads. Not so good on the hills or corners. Made a shit noise in the back left wheel which I assumed was the wheel bearing. Replaced bearing, same issue. Axle was bents, found a spare from my buddy and got it machined to match. Drove it all of 20km and lost the axle locking collar while out visiting a 240c coupe. Sourced another locking collar thinking I installed wrong. Same issue. I’m pretty sure MyTools.com supplied an I correct size but I’m no engineer so off it needs to go to be assembled where it can’t fail. 80km/hr on state highway 1 with the kids in the back wasn’t fun 10 1 Quote
Popular Post 30DegreesRetarded Posted April 25, 2023 Author Popular Post Posted April 25, 2023 So currently after getting some serious anxiety after having my family in car after said event, it’s waiting to have the whole diff sent to engineers to rebuild axle. It is now currently sitting in the garage waiting for house projects to dry up so there’s money to spend on diff. plan is to get road worthy again and drive. 15 7 Quote
Popular Post 30DegreesRetarded Posted May 2, 2023 Author Popular Post Posted May 2, 2023 Last nights efforts, I got a little motivation to pull the rear out. Will send to chch on the next road trip. Usual expectations with the metal shavings in the diff oil. In my journey doing this, I made the mistake of stepping in the brake while the drum was off…so now I need a rear brake cylinder seal repair kit. For those curious, current diff is 100mm shorter than stock. In other news I also replaced the exhaust gasket and two into one gasket. Quiet as now. 15 Quote
Popular Post 30DegreesRetarded Posted August 1, 2023 Author Popular Post Posted August 1, 2023 And we are back together. Spare axle went to MS Coombes in chch who disassembles it and moved it onto gear cutters to match up the new axle and then back to Shane to reassemble. 11T of pressure later and locking collar is on. Where I went wrong was heating my collar in the oven and driving it home with a steel tube and brute force. Apparently the heat damages the hardness of the collar and it doesn’t shrink/hold its original shape. So in theory we should be legit. Lesson learned. I cleaned up the diff and leaf springs while out. Nothing professional but looks better than before. wire wheel rust primer and paint. I took it for quick test drive. Sounds good at 50kmh so maybe take for a WOF. Thinking it will likely fail but who knows. Definitely need to adjust handbrake 31 2 Quote
Popular Post 30DegreesRetarded Posted August 20, 2023 Author Popular Post Posted August 20, 2023 Took for a WOF. Fairly happy with result. Bump stops having been hacked when sacked and needs reflectors on rear. Tyres were no issue. 1” lowering blocks are too skinny over leaves so need replacing too. Will sort new 2” ones so no issues there. 14 Quote
30DegreesRetarded Posted September 22, 2023 Author Posted September 22, 2023 Fresh WOF and Rego. Hayden (unsure of his old school name) just welded a 10mm plate to either side of the lowering blocks. Def looks like it needs another 1” to get rear low enough but good for the moment. New 2nd Hand bump stops on front and rear. Job done. Was struggling a little mentally with putting car seats in so figured I’d send to a Nissan mechanic to look over for peace of mind. Really glad I did as what they found was: 1. Front left bottom arm loose as a goose. Tightened up. 2. Both front tie rod end boots fecked, actual rods all good. They suggested replacement. 3. Park not locking up, readjusted rod from stick to transmission. Park now locks drivetrain. 4. Rear brakes backed off and readjusted (were way unbalanced). 5. Freed up handbrake cable a little more and adjusted to work. cost to wallet… FREE absolute legends. The front bump stop distances between stop and contact point (unsure what it’s called) are uneven. One has 2finger space while the other has less than 1finger between. Springs are brand new v6 HQ. Is that normal? 8 Quote
30DegreesRetarded Posted December 28, 2023 Author Posted December 28, 2023 Pulled front sus out to take a look and try replace damaged/non existent dust boots. Tie rod ends were easy to measure and replace from shelf. bottom & top ball joint has a complete replacement (apparently) but the taper is bigger then my H330 measurements. instead I purchased the Nissan Terrano bottom ball joints just swapped out the dust boots over. Cost me a whopping $12 for the two so they were easy purchases. I have 2xD21 bottom ball joints going free if anyone wants (minus the dust boot of course). im still on the hunt for some dust boots to fit the top ball joint. Can’t bring myself to buy a brand new D21 single for $90. Will try the wreckers first. im trying to decide how fussy I should be with reassemble of suspension ... Do I completely strip clean, powder coat etc or just give a clean and reassemble. Left one is the D21. Right one is the H330 with stolen boot. 12mm holes and larger taper, shame it’s not a complete swap. 8 Quote
30DegreesRetarded Posted March 15, 2024 Author Posted March 15, 2024 I’m stumped. so I’ve sorted all the dust boots, reassembled to what I thought would be exactly the same set up. But no the passenger side assemble sits lower than the drivers side. (I finger space vs 2). pulled apart again as I read potentially have left and right spring around wrong way…pulled springs and shocks out but I’m dammed if I can tell ‘em apart. springs are HQ 6cyl with identical markings. Spring perch is the same. Would camber spaces/shims have anything to do with it? now that I’ve looked at the dam things so long I can’t remember which one was in the left or right. 3 Quote
30DegreesRetarded Posted July 16, 2024 Author Posted July 16, 2024 Got windows tinted. Drove over to Nelson to do it, and she went smooth. I think they look good so I’m happy. 6 Quote
30DegreesRetarded Posted July 16, 2024 Author Posted July 16, 2024 Had some 2” blocks arrive for the rear. However I went to fit them tonight and I can’t seem to get them to fit without the bottom purch plate thingy (rear shock attaches to) to fit without it hitting the wheel rim. 4 Quote
Popular Post 30DegreesRetarded Posted September 27, 2024 Author Popular Post Posted September 27, 2024 Found a sedan rear sway bar to fit to the wagon. Already had the mounting points on the diff so assumed it would fit up sweet….nope. No bracket coming off the rails. Unsure if the effort to cut and weld in the mounting points is worth it. also, started just a general scrub/clean and somehow got distracted. Not paintshop spec but better than what it was. Where I could I rubber wheel’d down to steel but there wasn’t enough patience to wheel all of it. Plus the bloody primer never went hard. That sucked balls as I then had to thinners the whole dammed thing off and start again. 12 1 Quote
30DegreesRetarded Posted September 28, 2024 Author Posted September 28, 2024 Okay … so this is a little bigger than an A series. My first attempt at checking tapets take 1 5 Quote
Popular Post 30DegreesRetarded Posted November 18, 2024 Author Popular Post Posted November 18, 2024 Tappets went smoothly. Only had to adjust three all up. Need to buy a timing light. I ended up getting a WOF but failed on a leaking break line. Turns out I needed new rear shoes and one of the valves were leaking in the rear left drum. Local brakes shop couldn’t help so off to chch for a rebuild. Managed to pick up some shoes for $4! Couldn’t fit the 2inch blocks as they hit the inner wheel. So reset leaves back in and off to Nelson for a Wet Datsun Nats. 3rd kid arrived last week so now I def don’t have time for working on the wagon. But the kids have some time spare. 19 Quote
