Popular Post arswenson Posted March 16, 2023 Popular Post Share Posted March 16, 2023 A bit of a thread to follow my 1979 KE35 build. I purchased the car back in 2014 with plans to restore and repower with a 20v 4age. I will add notes and pictures from the start to where I am now. 11 Quote Link to comment Share on other sites More sharing options...
arswenson Posted March 17, 2023 Author Share Posted March 17, 2023 So this is the Ke35 on purchase day, January 1st 2014. Drove up to with a mate in his Mazda 1600 Ute and drove this about 400kms back home. The trusty 5k didn't miss beat, apart from having to wind the windows down due to the exhaust leak. 4 Quote Link to comment Share on other sites More sharing options...
arswenson Posted March 17, 2023 Author Share Posted March 17, 2023 After driving the Ke35 around for a few months i decided to start stripping it out to have a good look at how much rust was in it. Most of the rust is in the rear section of the car and the usual places in the front guards and radiator support. I got another tail section with the car so planning on taking rust cuts from that as much as I can. The other thing I found was the wiring behind the dash was a mess, the loom was cut up in places and a half ass job done to reconnect. 3 1 Quote Link to comment Share on other sites More sharing options...
arswenson Posted March 17, 2023 Author Share Posted March 17, 2023 I purchased a big port 16v 4age with the hopes of a simple rebuild and could start the process of repowering the car. Once i got the engine apart I started to realize that the engine i had bought was a complete dud and would be a big job to rebuild. I imagine the engine had a hard life and 3 of the 4 pistons were held together by the rings, the head was warped and the cam journals were less then ideal to rebuild, off to the scrappy with this engine. 4 Quote Link to comment Share on other sites More sharing options...
arswenson Posted March 17, 2023 Author Share Posted March 17, 2023 After some though and discussions i decided to forgo the 16v and look into a 20v option. I found a running engine that was fairly well priced (should have been a give away). The seller mentioned that it smoked a little but this was normal for 20vs with high kms, having owned a levin I knew what he meant. On tear down inspection a few alarm bells started ringing, yet another set of pistons held together with the rings and rods that had seen better days and a crank with some deep pitting and damage from thrust. I decided that i would make this work and buy replacement parts for the 20v. 4 Quote Link to comment Share on other sites More sharing options...
Popular Post arswenson Posted March 17, 2023 Author Popular Post Share Posted March 17, 2023 I had all the machine work done locally, new pistons from Toyota and rods from MRP as well as a replacement second hand crank. Bottom end turned out really nice and felt great to get another step closer to going in the car. 13 Quote Link to comment Share on other sites More sharing options...
Popular Post arswenson Posted March 19, 2023 Author Popular Post Share Posted March 19, 2023 The 20v long block is now all done, with some extras from SQ engineering and MRP. I had a mate turn up a small pug for the dizzy block off as having the dizzy in place with the MRP cover would hit the firewall. The head got a light porting and some polishing which turned out pretty nice. I scored a 22 spline T50 for a good price with an S series bellhousing but scored a cheap T series bell housing for it. I got the trumpets from guy in Tauranga, they are hand spun and a really nice bit of kit. Next on the cards for the engine is a trigger wheel setup and single row pulley. 28 Quote Link to comment Share on other sites More sharing options...
arswenson Posted March 31, 2023 Author Share Posted March 31, 2023 Finally got the old girl into the new shed along with my mates 1981 KE70 sedan, time to make a start on the rusty parts of the body. There was a large hole on the passenger side of the rear window which i cut out of the spare tail end I have. When I started on the passenger side taillight I found an old repair that was done with rivets and bog, looking further into this, the entire bottom of the boot seal lip was also riveted and bogged over, going to be a bit more work than I first thought. 9 Quote Link to comment Share on other sites More sharing options...
arswenson Posted March 31, 2023 Author Share Posted March 31, 2023 I have booked the car in to be blasted in a few weeks time so i decided to start taking some of the larger panels off to make sure i got right in to the bad spots. I started with the scuttle panel. The inside wasn't too bad but the underside of the top panel was a bit rough. I tidies up the inside with a wire wheel and small sand blaster and painted with a coat of grey zing and a couple coats of black zinc. I then moved onto the front panels, these had some horrible epoxy paint on them that wouldn't come off with the wore brush so ill get these blasted as well. I also removed the lower radiator support as this was pretty rusty, ill see how I go after blasting I may need to buy a new one. Lastly i removed the rear panel, I originally wanted to repair it in place but after much discussion with a mate I decided to remove it and start from scratch. Luckily i did, the drop panel in the boot is really bad and will make it a lot easier to blast inside the boot with the panel removed. 9 Quote Link to comment Share on other sites More sharing options...
arswenson Posted March 31, 2023 Author Share Posted March 31, 2023 I borrowed a tip jig off another mate and decided to get stuck into the underside of the car. Most of it isn't too bad but the front chassis legs have seen better days. The drivers side chassis leg was ok but was bent out of shape, I removed this and cleaned up the inside of the leg and the underside of the car, gave it a coat of zinc and welded it back on. 9 Quote Link to comment Share on other sites More sharing options...
Popular Post arswenson Posted March 31, 2023 Author Popular Post Share Posted March 31, 2023 The passenger side however was a bit worse, there had been a repair some time ago and they have simply welded a plate over the rust which then ate away at the new panel and made and even bigger mess. This one i will have to do in stages as its an odd shape. I started with the front most part which is relatively straight. Again just cleaned it up inside as much as i could gave it a good coat of zinc and welded a panel back in. This one took a bit of massage but i think it turned out pretty good. 13 Quote Link to comment Share on other sites More sharing options...
Popular Post arswenson Posted April 7, 2023 Author Popular Post Share Posted April 7, 2023 A quick update on the chassis leg repair. I managed to use the rear section that was in pretty good shape and made a new middle section. I think it turned out pretty well, as usual, coated the inside with a coat of zinc and black zinc. Shouldn't have any issues with this for a while. I also stripped the inside roof back as it was covered in the old glue and some furry left overs from the roof liner and gave it a coat of etch primer to protect it until its gets painted fully. 14 Quote Link to comment Share on other sites More sharing options...
arswenson Posted April 10, 2023 Author Share Posted April 10, 2023 So its been a pretty productive long weekend. I decided to get stuck into the front drivers side inner guard part that was full of holes. Someone had a go at repairing this in the pasty with pretty poor results. I gve it a good clean inside and hit it with some zinc as usual. Then i moved onto remaking the part that holds the captive nuts for the fender to bolt to and welded it in. The next part was pretty tricky for me to replicate as it had a few different curves in it. I managed to get something close and welded that in, here is the finished result. Don't look too close at the welds, this will be covered by the fender anyway. 6 Quote Link to comment Share on other sites More sharing options...
Popular Post arswenson Posted April 10, 2023 Author Popular Post Share Posted April 10, 2023 This weekend i also had a look at the radiator support, got this apart and cleaned the inside up. There was a few little pin holes in the lower section so welded these up, coat of zinc and welded it back together. I needed to replace both front parts on either side, made these in two parts since my metal working skills wouldnt allow me to do it in one, welded these up and a coat of zinc to finish it off. The last thing I did today was tidy a small part on the drivers side sill. I cut the small square out that was affected by rust, coated the inside and welded it back up. This part had a compound curve in it that I couldn't quite get right but a skim of filler will sort this out no worries. 11 Quote Link to comment Share on other sites More sharing options...
Popular Post arswenson Posted February 14 Author Popular Post Share Posted February 14 Been a little while since I updated. Made a start on the underside. I removed all of the old underseal and rust converted, it wasn't too bad for rust but a bit of rust converter wouldn't hurt. Once the bulk of the rust converter was done I hit the underside with an epoxy enamel, will then go over this with a textured underseal and seam seal the joins. 13 Quote Link to comment Share on other sites More sharing options...
Popular Post arswenson Posted February 18 Author Popular Post Share Posted February 18 Spent Friday night going over the seam with some sealer, this stuff is a shit to work with but should stop some unwanted moisture and eventual rust. Also painted a few areas that wont have undercoat. Surprised these cars never came with factory seam sealer on the underside, would have saved a heap of them from rusting away. 15 Quote Link to comment Share on other sites More sharing options...
