Popular Post HumberSS Posted March 9 Author Popular Post Share Posted March 9 Well behind on updates here. Slow progress, school hols and general business has not seen the results one ambitiously thinks will happen in the desired time frame. #projectlife. Where to start? Have now finished engine cradle including a few notches for critical engine bolts. Made a complicated pipe to move water around. Started with ally bends off aliex but ended up going with tighter ss bends I had. Have since swaged ends to help with pipe retention Next stop has been to get engine to a point where I can start it. Got a belt, made a dummy wiring rig for startup. Cunt won't start, have spark, suspect I m not pouring enough fuel down the hole, and also haven't checked if I have 8 sparks, so need to do that. Pretty sure I've got the timing bang on. It's using and early chev hei ignitor. Was hard to find definitive info on wiring but eventually got there, and spark at plug tells me I have done something right.. before doing that I used some clay to measure my seal thicknesses and ordered these, buttoned up rocker covers with fresh coat of wrinkle black, Im happy with the look. Really want to hear this bitch now. I managed to get in touch with the original engine builder, it was built about 20 years ago. It's had head work, skimmed, block decked and cam reprofiled. On cranking I was seeing about 40-50psi oil pressure which is reassuring. Other things. My mate has been doing some of the bolt on panels as he owed me a favour. I've also been partaking in my other favourite pastime of staring at other parts, using motivational herbs, and figuring out next moves. Toilet will go under drivers seat, under the D40 Navara rear bench seats I acquired some time back. 11 1 Quote Link to comment Share on other sites More sharing options...
HumberSS Posted March 9 Author Share Posted March 9 More pics. Also, I only have 7 original plug leads and they are not flash, and one oddball. I'm really struggling to find replacements that fit and would appreciate any Intel on sourcing something suitable. Amayama list but no stock.. wondering if maybe I could butcher some 7M leads perhaps? 8 Quote Link to comment Share on other sites More sharing options...
Popular Post HumberSS Posted April 12 Author Popular Post Share Posted April 12 Been getting a bit done, cbf smacking out a big update right now. Couple weeks ago we got the bitch fired up. Thanks to the GC @fletch for his exceptional trouble shooting abilities.And timing light. Working on water pipes now so will hopefully be on to diff next Chur https://youtube.com/shorts/loj9hqDgwQE?si=C8Xhtq75FGZGLL2j 16 Quote Link to comment Share on other sites More sharing options...
Popular Post HumberSS Posted April 27 Author Popular Post Share Posted April 27 Posting a better startup vid, finally got it all plumbed up. Had a few comedies of error but she seems all sweet. There is a pretty decent oil leak under the oil pump drive so I need to have a look what's happening there, and the stupid silicon rad hoses don't seal up that nicely.. Aside from that, listen to it in all its glory! It's an angry little thing.. https://youtu.be/7W1fyjg7ixE?si=2oTXfh21blaNmg9b PS how do I embed the video? 11 1 Quote Link to comment Share on other sites More sharing options...
