  • Replies 125
  • Bearded Baldy
    126
Over the next year or two it got lovells springs and gas shocks in the front, big whiteline swaybar and nolathane bushes in a few places.
Pulled motor out and gave it a rebuild not long before my daughter was born. .030 mahle 8 cc pistons, lpg cam from kelford cams, impco model e reg and modified 2 barrel gas carb. Port castings removed and smoothed around valve guides. Head planed and ended up with 50cc chambers
Xe 2 wire distributor and bosch coil.
Copies of pacemaker headers but with tiny primarys(bought for 50bucks) 2 inch exhaust with coby resonator.
This lasted a few years until i ended up moving town and working next to the former lpg specialists. Going through their old stock and spares i pieced together a ca300 mixer and snorkel. At around the same time the exhaust got hooked on the hoist at work and suffered a terrible fate. Quick weldup of 2.25 pipe to an old turboflow style muffler and bent to shoot out infront of the rear wheel. That temp fix lasted for another few years haha until the rust started being noticeable under the vinyl roof, at which point i put rego on hold and tore the roof off. Since then have gotten a mortgage and car has sat around, been legal on and off since then, 2013.
Cleaned up the ports some more while i was there.
Tracked down a center console that was pretty rough, so recovered it in vinyl.
20171228_085404.thumb.jpg.19ea24a759d71f57159eb78e1f1a3224.jpg20171229_161152.thumb.jpg.5c5510c15527ef1cbe5df17c4753a91f.jpg
Shifter hole looked pooze so grabbed a piece of alloy plate and polished it up.
  • Like 8
Anyway back on track. Once the cam was dialled in, rocker guides file fitted and beers drunk. It was time to drop the motor in and get to work on the exhaust. 2.5 inch with single muffler, up and over the diff and out in the o.g spot after years of bogandumping out the side.
Tucked up nicely.
  • Like 8
During the 4 speed swap decided i wanted to change to hydraulic clutch too. Problem being that from XC on the 6s had cable clutch.
Good news is that there is a workable way using o.e spec parts.
XB 6 cylinder 3 speed bellhousing. Need to open up the center by approx 4mm, just measure the gearbox front plate, mark the ball and go hard.
Now it sits flat, only 3 of the 4 gearbox-bell bolts line up, bolt it tight, mark where you need the new hole, remove gearbox. Quick drill and tap and you are done.
Will add what release bearing i used here* when i remember.
** part number GSB117 **
Unbolt cover plate on firewall and fit master cylinder. Fit XB slave cylinder.
Remove cable clutch pedal from box and fit hydraulic pedal and clutch/brake shaft from a v8 box (or rarespares etc if cannot find new).
Job done.
Current intake of choice is Redline Torker 2 barrel with a 500 Holley on it. Have run a 350 before and it was at its limits with the smaller cam setup. Fuel supply is by a Facet solid state pump mounted by the tank.
This is far far far from optimal with the 500.
So i have decided to go big, have sourced another tank from a later model wagon that appears to be the right mounting. Will need to replace the intank pump with better one i.e walbro, Will make and fit new fuel main and return lines (no return line atm), adjustable regulator up the front to finish it off.
I also have a 600cfm vacsec Holley here which would be ideal, but will need either an adaptor or new manifold. If i have to get a new manifold i would rather buy an Aussiespeed one, but that requires an alloyhead swap, which means i need to find the right head option.
Bit ugly but joints are good and yoke should clean up with some wetndry.
Shit is getting harder to find so grabbed this as soon the diff seller said he had a matching driveshaft, i didn't ask if it was any good just said how much, it was free so yeah mint!
Have head. Ports are far better design the ironhead currently fitted.
Will price up options of bigger valves etc before i go too crazy on cleaning up the throats and reshaping chambers.
also soooooo much lighter.
Changed my mind about the shed, want car on the other side so i can still use lathe, grinders etc, and most importantly reach the stereo.
So for todays mission i am reorganising the shelves and moving shit from side to side. Another crate of rubbish full already. Still not convinced it is all mine....
