all out of order bit found  more photos of rust repairs to boot floor , inner and outer rear guards, just everywhere really
Sandblasted the fuel tank and was rusted from the outside in. Ended up brazing up the holes and putting gas tank sealer stuff in it.Was nice and clean inside bit wanted to seal up where id been welding. Seems to have worked a treat.
  • 4 months later...
Finally got the car back from the upolsterers.
Looks decent, got the boot done as well. Had a crack at covering the dash in vinyl which came out ok.  Want to get a proper moulded  remanufactured dashpad  but the dashboard place needs the steel frame to make a mould off which is a bit hard because its welded in so have to cut the bulkhead out of a car and take it to them for that to happen.  Otherwise  continue on with putting it back together
  • 3 years later...
