Popular Post Benno Posted January 4, 2021 Author Popular Post Posted January 4, 2021 Got the boot floor repair patch sorted, made a wooden template and hammered the side to suit. Cleaned off as much rust as I could in the boot strengthening crossmember, treated with Brunox. I will paint the areas I can with some epoxy primer, will get some cavity wax down to the areas I can't before I weld the floor path in. Started making a patch for the boot edge. Started off with my high quality sheet metal brake Clamped and welded to some SHS, hammered to get the right profile Fairly happy with the end result, will still need some minor shaping before I weld it in 20 Quote
Popular Post Benno Posted January 24, 2021 Author Popular Post Posted January 24, 2021 Slowly but surely getting on top of the rust. Got the boot floor patches all welded in and painted with epoxy. Been working on getting the outer edge sorted. Wasn't keen to section the whole length to get the curve right. Got myself a shrinker/stretcher which made things much easier. My first attempt was to make a jig which had the right curve, bend a right angle then hammer to form a profile. Results weren't great, so back to square one. Cut, bent and welded some box tubing to get a curve the same as the boot. Welded and clamped on the bent and stretched angle, hammered flat. I butt and plug welded it on. Now just working through smoothing out the welds with a flap disc and power file. 28 1 Quote
Popular Post Benno Posted April 20, 2021 Author Popular Post Posted April 20, 2021 Finished removing the underseal. What a shit job, lying under the car scraping with a chisel. Only a bit of surface rust, cleaned up no worries with a strip disc and wire brush. Gave it a coat of Brunox, scuffed up with scotchbrite and brush painted with epoxy primer. Not mint, but good enough for the underside. Just need to move the stands and do the same for the jacking points now. Getting the fuel tank dipped and lined, rear brake cylinders sleeved at the moment. Next, I will tidy up and paint the diff and fuel tank. 31 Quote
Popular Post Benno Posted May 9, 2021 Author Popular Post Posted May 9, 2021 Got the fuel tank back. First pic is before it went to the radiator shop. Had the remainder of an existing liner in there, so he had to split it and sandblast to get the new liner to stick. He also knocked out the worst of the old dents, so I am happy with the outcome. Stuck some brunox on there and have got into epoxy. Found some denting on the sills which is a bit annoying. Guessing it has fallen off a jack at some stage, unfortunately it's got similar damage on both sides. Not sure what I will do here yet, I think it is within the VIRM spec so I might see if I can just get signoff for it, then bog it up later on. 13 Quote
Popular Post Benno Posted May 16, 2021 Author Popular Post Posted May 16, 2021 Got the fuel tank painted in 2K black. Took the front and rear windscreens out and doors off. Fortunately no rust around the window frames which I was a bit worried about. Now working on the boot area. While I'm removing paint, sound deadening and rust I've got some of the diff mounts in the electrolysis bath to clean up. 13 Quote
Popular Post Benno Posted July 6, 2021 Author Popular Post Posted July 6, 2021 Got a container of bolts, nuts and brackets vapour blasted and zinc plated. Really happy with the result, certainly beats manually cleaning them with a wire brush and painting. Got the brake MC rebuilt by Undercar. Been busy with the strip disc removing all the paint from the boot and body. Found a few less than ideal repairs, covered with lots of bog. Considered just bogging it back up, but decided it would always annoy me if I did so going to get it fixed by a panelbeater. Will get the crushed sills fixed properly at the same time. 24 Quote
Popular Post Benno Posted August 29, 2021 Author Popular Post Posted August 29, 2021 I decided that if I bogged up the rear quarter and sills, it would always annoy me. Planning on keeping this car, so wanted to get it right. After I'd finished stripping the car I took it to a panelbeater, who is doing an awesome job so far. Getting a repair cert done at the same time to try to make re-vin as easy as possible. So far so good, but covid has put a bit of a handbrake on getting it finished off and back. 17 Quote
Popular Post Benno Posted August 29, 2021 Author Popular Post Posted August 29, 2021 Unfortunately, I've got an office job so don't have any free time over lockdown. While the body is at the panelbeaters, I've been working on stripping the front valance and gaurds. Front valence wasn't too bad. Wee bit of bog, but I was able to mostly straighten out the wee dents without too much trouble. Can't say the same about the guards. Looked fairly good, but shitloads of bog and some horrendous repairs. Unfortunately there is a support for the guard, so I can't easily get to the back of the indented bit. I will have a go at welding on some tabs and pulling it straight. Don't mind a wee bit of bog, but that is taking the piss. Cut out the shitty bit at the front first, will sort that bit out first. 15 Quote
Popular Post Benno Posted September 16, 2021 Author Popular Post Posted September 16, 2021 Panelbeating all sorted, signed off by the repair certifier. Really happy with the work that Delray did, would highly recommend. I got them to give it a sand and coat of epoxy primer too. Now just need to sort the boot and a few wee bits that need a light skim of bog. So much better than what was there previously. 25 Quote
Popular Post Benno Posted October 31, 2021 Author Popular Post Posted October 31, 2021 Wee skim of bog over the repairs and some other small dents. No more than a couple of mm, much better than the >10mm that was there before. Repeated the bog, sand, filler primer, sand process a few times until I got it to the stage I was happy with it. First coat of colour went on a bit dry, so I put a bit more thinner into the second coat. Wee bit much it seems so have got some runs. Hopefully will be able to wet sand out without too much trouble 24 Quote
Popular Post Benno Posted December 2, 2021 Author Popular Post Posted December 2, 2021 After the painting I pulled the diff and springs back out. Painted the boot with 2K black. Cleaned off all the rust from the springs. Bit of pitting, but not too bad. Treated them with Brunox, painted with CRC Black zinc. Then got them reset and riveted at Bellamy and East, really happy with the job they did. Next I bare metaled the diff, epoxy and 2k black Re-did the worst part of the guard, not perfect but now only a few mm of bog needed Also made a new inner guard nose. Guessing mud etc gets stuck behind it, which rusts it out 22 Quote
Popular Post Benno Posted December 12, 2021 Author Popular Post Posted December 12, 2021 Got a the bonnet, boot hinges, front cowl, indicators and inlet manifold vapour blasted. Came up really well. Gave the blasted parts, guard and front valance a coat of epoxy primer. Found a rebuilt mk3 engine on trademe. No receipts so a bit of a risk, but better than the mk2 engine I previously had lined up for it. 20 Quote
Popular Post Benno Posted January 9, 2022 Author Popular Post Posted January 9, 2022 There was a bit of rust in the LHS guard, I got a 'good' replacement guard off trademe. Turned out the replacement guard was full of bog, so back to the original. Cut out some previous repairs. Still a bit of bog in there, but less and not as thick. Painted the inside of the guards and valance with 2K black. Painted the outside with 2K primer filler, top coat around the edges. Have bolted back onto the car to do the final bogging and sanding, too much flex otherwise. 21 Quote
Popular Post Benno Posted August 9, 2023 Author Popular Post Posted August 9, 2023 I had a son last year, so progress has slowed down on this but still happening. Managed to get the guards, valance and bonnet prepped and painted. I got a bit of dust in the paint, but I'm happy enough for now as I'll be putting on another coat later on. Now onto the doors. A couple have had some dents in them, so heaps of bog. I've stripped them and having a go at straightening with a hammer and dolly. One of them had been cut with a plasma cutter then not welded back together, I'm going to tidy that one up. 20 1 Quote
Popular Post Benno Posted March 15, 2024 Author Popular Post Posted March 15, 2024 The door with the plasma cutting was pretty wonky, so ended up finding a replacement. Managed to get all of the doors paneled and into paint. A bit of dust and a couple of runs, but I'm definitely getting better with the paint gun. Now working on sandblasting the door hinges and cleaning up the boot lid, before reassembly, wet-dry sanding and a final coat. Stoked to be making some good progress again. 26 Quote
Popular Post Benno Posted October 2, 2024 Author Popular Post Posted October 2, 2024 I reassembled, wet sanded with 800 grit and put another coat down. There were a couple of runs, in the process of removing them I rubbed through to primer in a couple of spots. I masked up the doors and front guards which were OK, resprayed the rest. Unfortunately there was a gust of wind near the end which blew some dust into the paint. Fortunately, I've been able to wet sand out with 2000 grit and polish. Starting to look pretty good now! 23 Quote
Popular Post Benno Posted April 28 Author Popular Post Posted April 28 I've been re-assembling. Got the tail lights and quite a bit of the chrome trim installed. I used some vinyl paint on the seats. The seats have come up pretty well, a couple of rips but should be able to fix with some tape and a seat cover until I get them reupholstered. My engine was supposedly rebuilt to factory specs not long ago. No receipts, but it looks clean inside and turns over with good compression. Should be fine to get it running, re-vinned and I can build up another motor with a cam and higher compression. Bit of a mission to install with the gearbox on, but smashed it out with a couple of mates. Would probably do it with the gearbox off next time I think. The next big step is going to be to suss out the hood lining so I can get the front/rear screens in 24 Quote
