Hello everyone, I will try to represent my car. It is ultra RARE version of Galant, with a lot of modifications. Been working on this car for 7years, so updates will keep coming :)
Its in family for around 20years, second owner
A lot was done on this car, so i will try to represent it step by step, its a very detailed topic, for true lovers
so lets start
1987 Mitsubishi Galant 2.0Turbo DOHC RalliArt
Odometre
137xxx km
Engine Hardware
4G63T- 2.0T DOHC - 16v, 6bolt
313HP
395Nm
Transmission
5 Speed MANUAL
gearbox from 2.4engine(4G64)
Engine Modifications
Vems standalone management system
Blow off-Turbosmart dual port
boost is on 1.3bar
exhaust 70mm(rear custom made muffler with electric cutout)
intercooler from EVO10
walbro 255lph fuel pump
intake box & k&n filter
560cc injectors from EVO9
Bosch lamda LSU 4.9
Bigger fuel filter, OEM from Eclipse 2G
EVO2 BIG 16G turbo
EVO2 manifold
EVO2 O2 housing
EVO8 hrottle body
intercooler pipes from steel and polished
second ventilator for better cooling
water cooling for intercooler
Eclipse coils
hks turbo timer
Brakes:
Brake booster from Nissan S14 + brake master cylinder from Carisma GDi
Brembo 4pot brakes,320mm slotted and drilled willwood discs + ABS
rear standard Turbo
Suspension Modifications
Front:
Cusco coilovers
Strut Brace
Rear:
Cusco coilovers with adjustable dampers
strut brace
Wheels & Tyre Modifications
17" OZ Superleggera
215/45/17 new Continental ContiSportContact5 tyres
Exterior add-ons:
RalliArt body kit
rain window visiors
RalliArt mudflaps
Interior Add-ons:
power mirrors
power windows
red light illumination
OEM EVO9 RS triple gauge set
original power antenna
headlight washers
cruise control
On begining it was a stock 2.0(4G63) carb
Then I got a RalliArt body kit in very bad shape, and spend around 200hours to get it in lets say good shape
DSC03901800x600.jpg?t=1312041703
DSC05759800x600.jpg?t=1312041534
DSC05657800x600.jpg?t=1312041545
DSC05653800x600.jpg?t=1312041546
Some polished stuff
So going with the engine
It was a stock 4G63 carb engine with 102hp
then i got original 2.0Turbo engine , known as a G63BT 8 valves, with 150hp
after some modding , adding up a intercooler, and settiong boost on 1.0bar it pulled out 175hp, but the power above 5000rpm was pretty bad
So i decided to go multipoint
i got a Megasquirt 2 Extra, intake manifold from 2.4 engine, 450cc eclipse injectors
after a lot of hard work, result was great, 227hp@5000rpm and 348Nm
Also then, i have painted a body kit, so all was looking much nicer
The story goes on
As turbo was very old, it starded smoking on idle, and i got a great deal on a DOHC engine, so the DOHC came in from eclipse, and i sold my engine to Austria
Then i started to rebuild the engine
First parts arrived
ARP head studs
set for balance shaft delete
injector rubber
oil filter x2
oil cap gasket x2
O2 housinga and downpipe 70mm gasket
C9CB5CE7-AF4D-41CF-B61F-B8A1F94B515C_zps
91E51F29-7553-43C3-8272-8F8128E2D828_zps
1C558605-BBEB-4B1A-B50B-68567ECA1B32_zps
34A8EF46-B0E4-4D8F-8947-1977E901BE1C_zps
engine dissasembled
then balance shafts are out, total weight save is 2.9kg
OEM part for oil pump housing
then the cleaning part
valve coer was in pretty bad shape
piston before and after
then next part was block
painted
new OEM parts
FDFEA562-EBD8-4C60-A0CD-96368CFA7180_zps
head cylinder is dissassembeled
6DF50EF8-EDDE-4206-8F96-357D6AB26EA9_zps
EBEF740A-B6A0-4E34-8ED3-4FAD355D8445_zps
exhaust valve, before and after
42C9103B-0AFC-45E3-A1D5-88880D0E11AB_zps
washed oil pump
D629685F-477B-4ABE-BDB1-4B6E54C894CE_zps
8674DEC1-F0FF-4E6C-975F-4FE41B6BB91E_zps
all pistons are cleaned up, after 15washes
all is washed, and ready for install
valve cover painted
5B65EC10-684A-461B-A65C-BC6642C458D2_zps
5DD28202-A0F9-4494-9C68-86E2E4E5F506_zps
painted exhaust manifold, turbo housing, o2 housing and covers
08DC12AE-3E8C-41EC-8E1C-01CB8360D857_zps
oil pan cleaned up and painted, also a timing cover
machine work done
honed and surfaced block, surfaced valves, surfaced head, and a polished crankshaft
how it should look when i will start assembley
 then i got mitsubishi eclipse 3g lifters
difference between 1g and 3g
next is cleaning, and working on a port job on the oil gallery on the block (where oil pump sits)
head on its place, torqed
thermostan housing, camshafts, lifters, rocker arms etc ,all in its place
its really nice to put all of those things together while they are so clean
thermostat housing
thread locker on the oil plug for oil gallery on the head
pice before and after galvanized
coil and power ignition mounts
then i got a third valve cover, painted in original silver with red letters combination
intake OEM gaskets and galvanized bolts
i got an exhaust turbo, manifold and o2 housing from evo2
Aisin water pump came in
i was in Budapest for a New Year and i got few (read a lot) spare parts for Galant
4 of us were in Budapest so i need to organized it very well
also i got rare genuine mitsubishi wheels for Galant / Sapporo 81-84, as far as i know there are 4 sets in my country, and i have 2 sets :)
i got genuine front brake pads for EVO3 calipers
10872446_10204077847520382_943702524_n_z
oil pan is installed
10877671_10204078047125372_1742288242_n_
finnaly i got the last package with parts
turbo is restored, had a few broken bolts in it, but now it is like new
Difference between Eclipse 1g and EVO2 exhaust manifold
Turbo is prepared
another round from galvanized
New and old water pump
