Popular Post RallyRolla Posted November 9, 2014 Popular Post Share Posted November 9, 2014 EDIT: Discussion thread here---> //oldschool.co.nz/index.php?/topic/45833-tores-toyota-corolla-ke20-1975-rallyrolla/ Hey, my name is Tore (17), I'm from Vang I Valdres, Norway . I'v been obsessed with cars since i was a kid..here is my cars, The 1969 Toyota Crown, swapped the original 4 cyl for a 6 cyl, runs good, and my 1975 Toyota Corolla "Rally Rolla"Here is the Car when i bough itsomeone just bogged painted over all the rust... but they used the wrong color so i could see where they have done thingssoo i started rust repairingde-badged the whole carbought myself a parts car for hte wndscreen and the front platenew front platestarted bogging the carthe final boggingbought myself some seatspaaaainnt, painting done by dad, masking by meneeext colormasking off for the next layerwhite is on and masking is offgot hold of a luisi wheel and a toyota boss, made myself a instrument panel aswellseatsadded 2 fog lighs since this photodetailsmy Old school Toyotas and my brothers s13the face i make when driving the corolla size does matter? or not? i enjoy the Corolla WAYYYY more than the S8then to the Crownbought it whit a slow 2 liter 4 cylinder...got hold of this from one of the ms85's dad got, had to swapp the tailshaft and diff aswell..polished valve coveradjusting valvesadded white writing to the tyresand then i added a deluxe grilllow at the rearfirst test with new enginethe parts car i took the engine out ofgoing back into the bushwill update when stuff happens ooohh and last weekend i bought myself an 1982 Toyota Carina Ta60 with bike carbs, and welded diff, just to use on the fields 3rd gear dissaperd a couppel of days ago so it seems like i will have to rebuild the T50 gearbox 39 Quote Link to comment Share on other sites More sharing options...
RallyRolla Posted November 10, 2014 Author Share Posted November 10, 2014 Discussion thread added at the top of the thread ________________________________________________ FFFF**** this shit! myc back is all destroyed, my neck is in massive pain, iv beeen laying under the Rolla yesterday and today after school, trying to figure out the freaking exhaust leaks, trying diffrent bolts and shit... first problem--> the car will not fill the lift.. so i had to improvise problem number two, the gearbox fell down... soo therefore Warning the weldign is crappy as i have to lay flat on my belly and then try to raise my head and hands to weld... its freaking impossible and exhausting! then i had a leak at the manifold to pipes, found out i was missing a bolt and missing the gasket then i managed to put the gasket the wrong way arround, im freaking hating that little 3k! been working on toyota M motors, and R motors, they are sooo much better to work on! why is the starter on the same side as the exhaust, Carb, and regulator?!??! you need a lift to change the starter without removing the manifolds... grr sooo then I'll drop by the Toyota dealership tomorow, and ill try to source a bolt that does fit 1 Quote Link to comment Share on other sites More sharing options...
RallyRolla Posted November 23, 2014 Author Share Posted November 23, 2014 I cant stand my rims anymore, but im out of money, its not free to get a licence and its not free to get this car registerd ... sooo i cant use any more money... anyways, got my new exhaust gasket, going to change that soon... and i looked at some pics of some other 13" teta rims, but this time.. polished! could not understand how they did get their plastic center covers polished but when i found mine i saw how.. a chip in in paitn revealed it all, they are plastic but have a aluminium plating over the front! sanded it down a bit, seems like someone painted i them with a crome spray then with a gray spray sooo im going to regret saying this but i am going to polish up my rims... going to take a loong time.. 1 Quote Link to comment Share on other sites More sharing options...
RallyRolla Posted November 28, 2014 Author Share Posted November 28, 2014 manifold off removed 2 valves before i went home aswell Plans -Hot Cam, from 246 durations to 270 ish -Shave the head, i need to measure the combustion chambers... i could need a bit of help here... -Port the head a bit, and the manifold -Re-grind the valves Quote Link to comment Share on other sites More sharing options...
RallyRolla Posted November 30, 2014 Author Share Posted November 30, 2014 Finaly got arround to draggin the Carina home again.. porpper equippment! 1965 Volvo Buster BM400! the Buster just could not do it so we had to get a 4x4... anyways , i got what i need rigggght here! Mikuni Flatslides from a 1100 GSX-R Now i need to make a manifold that fits the K series engien with the exhaust and inlet beside eachothers.. 2 Quote Link to comment Share on other sites More sharing options...
RallyRolla Posted December 1, 2014 Author Share Posted December 1, 2014 original carb looks small..Needs some portingSnapped all fraking boltsNEEEDS LOOOOTS OF PORTINGVery roughUsed a couppel of hours trying to match everything and get it "free flowing".. have to weld it up porpperly, iv just welded a bit here and there in case i had to take it apart...and it ended up very close to my brake pump... ill try to get it further back i love this! 3 Quote Link to comment Share on other sites More sharing options...
RallyRolla Posted December 2, 2014 Author Share Posted December 2, 2014 Keep in mind im no welder... i'v had a 10 min guid by graddad but nothing more... + been rust welding all this Freaking car and build myself a "gocart" but i did not learn so much started welding them upmust be free flowing when you can see out where the valve sits perfectsome small adjustments and i got them like 3-4cm further back moooar spaceroom here aswellas all of you know, if you cut a pipe at an angle it looks like an egg afterwards... so my pipes did not fit my holes...you can see the edge there.. a huge air block..all 4 had these..welded a bit inside there then grinded it back downa bit more cleaning up and they are perfect!lets just hope this is air proof... i just could not fit the weldder in between them so i had to do it this getto way.. Quote Link to comment Share on other sites More sharing options...
RallyRolla Posted December 4, 2014 Author Share Posted December 4, 2014 blocked off the exhaust hole and made a heatshield on the top of it and i finished welding my inlet manifolds rawr fits nicelyfloat bowls almost horizontallycylinders looks goodtried getting the cam cover off but i could not loosen the pulley wheelawesome frame number why i dont feel like buying RHD extractors..just cant get tired of looking at theese 1 Quote Link to comment Share on other sites More sharing options...
RallyRolla Posted December 7, 2014 Author Share Posted December 7, 2014 Engine out after some thinkin i got the cam out ewww cam and lifters i loove this lift, moves left and right on a beam that moves back and forth in the workshop all homemade Quote Link to comment Share on other sites More sharing options...
RallyRolla Posted December 12, 2014 Author Share Posted December 12, 2014 Shop cleanup nice angle! dirty and ugly just ugly ^Feeling like Mr. Beans BOOM my eyes hurt , I need to find a new spot for the regulator details the head is old on with one bolt so is the cam cover PURE LOVE not too much space here, cant get my finger in between thats if for now 2 Quote Link to comment Share on other sites More sharing options...
RallyRolla Posted January 10, 2015 Author Share Posted January 10, 2015 Parts 3 Quote Link to comment Share on other sites More sharing options...
RallyRolla Posted January 20, 2015 Author Share Posted January 20, 2015 Cam is now payed, hoping for them to ship it back today... Had nothing to do so decided to paint a bit Quote Link to comment Share on other sites More sharing options...
RallyRolla Posted February 8, 2015 Author Share Posted February 8, 2015 Cam and valve springs arrivednot much left on the backside of the cam!head is back from shimmingmount for the carbs and throttle wire holder madefirst a coupple of revs then a little drive! i need to do some exhaust work and a low pressure fuel pump 5 Quote Link to comment Share on other sites More sharing options...
