braden Posted October 18, 2014 Share Posted October 18, 2014 was wondering what need to change for a starion conversion on l300.just the gearbox and the hydraulic clutch?would I be able to use the clutch off my sigma turbo engine or they be different Quote Link to comment Share on other sites More sharing options...
braden Posted October 22, 2014 Author Share Posted October 22, 2014 bump Quote Link to comment Share on other sites More sharing options...
77magnum13hundy Posted October 22, 2014 Share Posted October 22, 2014 not sure if this is the same as an l200 gearbox but it can be done... go have a look in http://www.projectzerog.com/ for my mates l200 he got a AWD flywheel machined out a spigot bearing hole and found the smallest l200 clutch available with the correct input shaft. Its not that easy, cos you have to suss out the flywheel and change ring gear and make sure the starter works... also narrow or wide block will be the crucial matter. http://www.projectzerog.com/ Quote Link to comment Share on other sites More sharing options...
braden Posted October 23, 2014 Author Share Posted October 23, 2014 yeah I have a wideblock starion motor and would it be possible just to get a gearbox out of a 2.4l petrol l300 use that flywheel and clutch cause they work with the starion motors Quote Link to comment Share on other sites More sharing options...
77magnum13hundy Posted October 24, 2014 Share Posted October 24, 2014 Yes that's the right one that will bolt up to block... I'll see if it's the same as l200 as mentioned in earlier post Quote Link to comment Share on other sites More sharing options...
77magnum13hundy Posted October 24, 2014 Share Posted October 24, 2014 In your case it should just be sorting clutch plates and flywheel then... Quote Link to comment Share on other sites More sharing options...
77magnum13hundy Posted October 24, 2014 Share Posted October 24, 2014 Gearbox will be slightly different to what was stated with l200 one starter motor position etc... Will be a case of comparing them. Quote Link to comment Share on other sites More sharing options...
