rotor_dude - Mazda - RX7 - FB - Series 3
well a thread about my FB RX7's and my UK experience
i have a few lol
Series 2 - LHD - i'll start another thread for that
this thread will only be about my Series 3 RX7's
my first RX7 in the uk - Northern Ireland - a series 3
wasnt too many to choose from in ireland, well none, all rotten pos
wasnt many about uk either at the time, 2003ish, that i could find
no network for mazda's here lol
RX7 - FB - Series 3 - blue
got the usual, its mint, i asked is there any rust ? got no, well got the car transported from england to n.ireland to my work
looked good outside except for a bit of rust size of tennis ball on left rear quarter behind door
put in on the 2 post lift, put arms under, started lift in up position,
heard a lot of noise and russling, car still on ground but lift going up, thought better stop and see whats up
looked underneath, my welcome to the UK
lads in work called it the tetley tea bag among other things
i'll try and dig out my pics of it,
so £1000.00 down the drain, absolutely pos, owner wouldnt be nice and give my money back, start of my uk lessons about old cars and uk
so got it home, didnt know what to do to be honest, then heard about diffing, yes diffing,
so thought well why not, its all its good for now,
man uk rust sux shitte, every nut and bolt i tired to undo, snapped clean off, man love uk shitte cars, NOT lol
so i removed carb, modified to mechanical secondaries, put ngk race plugs in her, removed diff, took to work, welded her up, started fire, work college told boss, no more working on your own stuff at work, i set boss aside and said thats wrong and only i should be the one to not be able to work etc but didnt listen, told the nark a few things and boss lol, surprised i didnt get fired
so anyways, put welded diff in, cut off rear brakes and removed the calipers and pads etc, blocked pipes, for burnouts,
as shitte rusty shitte and didnt work, also crap copper brake lines if you could call them that, so sorted front brakes to work well,
had a pee shooter UK spec exhaust on, but bit better than factory
work had a recall on volvo fan units, controller crapping out, so scored about 10 of them, got told off again for taking them outta the bin lol told to hand back, yeah right lol
cut up the fan unit to bolt to the rx7 radiator, wired up to switch, fan was amazing, kept the thing at good temps after mega thrashing
so done a few wee other things, tested it out on lane next to house, went around ok,
next of to a diff,
wow is all i can say lol
they have big farmer tractor with mahoosive tank filled with water, covered diff pad for the cars, i had to ask for them to let it dry out, they didnt understand and werent to keen lol
i said want a dry track to burn rubber, got the funny look lol
so took her out, 1st and 2nd, done real well for the little carb fed 12A, have a few vids to throw up, make you laugh
so i used it for a few years thrashing it big time, having good craic as they say and opening a few eyes here lol
started working on rotors again, one customer had a series 5 rx7 13BT, engine blown, so stripped engine and quoted repair, never got job too much for him lol, but he had another series 4 rx7 for spares with a 13B, i was like cool, drove the back end of nowhere, dang country out in the wop wops lol, turned up had a look, it had an rx4 13B in her, i was like mega excited, put my game face on lol, bought it, mission to get home with my vauxhall astra mk3 1.4L big block and 4 wheel car transporter, but got home, removed engine, stripped car for parts and sent to scrappers
so removed the mount conversion, crazy
sorted gaskets etc, fitted 12A carb to 13B inlet manifold, modified headers for 13B, fitted into series 3
now the fun began, 2nd and 3rd gears, man it went around and created some smoke, got kicked out/banned from a few places as was a bit to loose for them lol
done this for a few years, then body became way to structurally unsafe, so parked her up out back of me house, removed 13B engine for another car/project
you still awake lol
RX7 - FB - Series 3 - Green - 12A
so bought another series 3 from england, should have learnt first time, rusty pos lol
patched her up wee bit, done some work on her, water seals went after few months, so the old magical start fluid :) every time to get her going lol
drove about for 6 months as mot ran out, then parked her up for a drag car,
then bought a LHD series 2,
was ok condition, had been badly patch welded under rear seats, sill be done but good,
refer this thread - (will be up soon)
then bought another series 3,
i like series 3 everything is better, ventilated discs front and rear, bigger axle diameter and splines, etc
so got this from england again, was told very good, which it was for a uk car, but i got spoiled in nz and not upto my taste
but it only needs major repairs to underseat area and sills, its worth doing properly though
so fitted an LSD, upgrade the front brakes to FC hub and discs and calipers and PCD 5x114.3 PCD
redrilled rear axles to 5x114.3 PCD also
had big plans for this, i deloomed engine bay, fitted an RX8 13B 6-port engine and 6 speed gearbox, IDA carb setup for now, go injection later, RX8 front seats, RX8 wheels, flared arches too, bit of an RX8 meets Series 3 RX7 project lol
but turned into a project and havent worked on it in awhile
well thats me waffling for now, fingers sore, i'll dig out pictures and videos, as easier to read them lol
discussion thread - //oldschool.co.nz/index.php?/topic/44328-rotor-dude-mazda-cars-discussion/
RX7 - FB - Series 3 - Blue - Pictures and Videos
this is with the little 12A heart in her
she got a little bit hot lol
the "diffing" crazy as man, you only allowed certain time, then they chase you out with a tractor or fork lift,
note they not shy, they will plough your car out of the way, not cared at all about damaging your car like, twas crazy crazy
near all were softies, always out and wanted a wet track, i asked why, they said didnt want to damage the tyres
im like seriously lol soft cough cough
RX7 - FB - Series 3 - Green - pictures and videos
i bought this as a rolling shell,
this is what is was like before i bought it
last owner had a wee accident lol
then this is how it looks now and what ive done to it
these pics are the RX8 13B 6-port and RX7 series 3 gearbox, which i changed to an RX8 6 speed gearbox
RX7 - FB - Series 3 - Green - Pictures and Videos
after mot(wof) expired, turned it into a drag car project
RX7 FD series 6 13BTT
RX7 FC Series 5 turbo gearbox
FD front hubs,discs, calipers
FD 17" space saver wheels, lol
have a mahoosive holset turbo for it
front mount intercooler
just standard diff to get it out and have a wee bit of fun, but then will run a hilux or mazda b series or a bt50
fuel cell
bosch 040 pumps
turbosmart fpr1200
4x extra injectors
ecu - going with apexi power fc
spent some time and craic removing the sound deadening, but came off ok,
