Miniman76 Posted April 10, 2014 Author Share Posted April 10, 2014 so its almost looking like new again just a few more things to sort out so we found some fcr 41 r1 race carbs flat slide down draught should make some gains over the standard r1 carbs will fit in the off season with the addition of disc brakes to the rear 1 Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted April 20, 2014 Author Share Posted April 20, 2014 so easter weekend brought on the final round of the super mini challenge had a good weekend wit ha hard fought 1st in race 1 and 2 2nds on the sunday so all in all great weekend so we were able to wrap up the open class championship and now development time begins for next season for now check out a few pictures that Greg (64valiant) took on sunday 1 Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted April 20, 2014 Author Share Posted April 20, 2014 also on the sunday we competed ina mini vs pre 65 challenge on sunday arvo which was pritty exciting to end the weekend untill the red flaged it 3 laps in with two minis ahead of the pre 65s 1 Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted May 11, 2014 Author Share Posted May 11, 2014 race seasons over we had a mini fun day at taupo to end the season and then had prize giving that night so we ended up doing around 65 laps of track 1 at taupo enough for me to feel the body the next day hahah but all in all went well broke an axel first one all season better to have hapend on the fun day than at a race meeting id say so slaped a new one in and away we went heres some pictures cheers to greg (64valiant) and Evan and the rest of the team for the quick change and also the tasks of beltn in passengers all day so with the dirty stuff outa the way was time for prize giving ended up doing pritty well i must say pritty stoked for a new build to not have many dramas and come away with 1st in the open class , 2nd overall , rookie of the year , and most inovate team of Gare Motor sports so really stoked that we were able to string it all together so as for now the cars jacked up and its development time hehe so cutting up old inlet manifold to make a new short one for the FCR 41 carbs we picked up so with this under way room for weight removal is under way on driver and car haha i will keep ya posted on more devlopment works as it happens as theres alot going on Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted May 25, 2014 Author Share Posted May 25, 2014 so today with some spare time with helping Evan with his s1 rx7 subframe i managed to remove the engine and fit the dumby motor to allow us to work out how much of the fire wall we are to cut away and also found some big issues which ill describe later so heres the front end with out the engine pritty bare i know but seems to do the job quite well haha from another angle so heres a block and gearbox cases i have to sit in for welding to so we dont risk anything on the race engine the block is a blue top block bored out for oversize but never ended up getting used and an old red top head i have laying around so with that in marking out of fire wall can get started ! so a major problem found today was our shocks are too short something we thought nothing off but is really costing us lap speed or corner exit due to the wheels wont go down with the anti roll bar well they go down but the drop like 10 mm which explains why we buzz the lh front at taupo all the time also found the tie rod to not allow the rose joint down which doesnt help either so off onto the web to find some new standard length shocks its amazing finding out this now how we the car did drive haha should be a million times better when we get the suspension moving correctly while the engines out i will throw a new clutch in as its getting hammerd of the starts with me loading it but after a season the linning and fly wheel and pressure plate still look good so will replace any way for peace of mind cause next season the motor stays in haha over removing it all the time for gearbox changes by for now 6 Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted May 28, 2014 Author Share Posted May 28, 2014 heres the beginnings of the new manifold for the fcr 41s 2 Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted May 29, 2014 Author Share Posted May 29, 2014 so today the inovate motorsports lc2 wideband turned up should help us tune the engine to be alot stronger with the fcrs on the fly Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted June 2, 2014 Author Share Posted June 2, 2014 so got bored this long weekend couldnt go anywhere with work so did some choping up of the firewall for a airbox and cleance for the new bike carbs and this will provide us with a hole to make an alloy airbox to clear the filters but heres the carbs sitting in there with the half done manifold and another angle this is going to allow us to use a standard looking bonnet no hump 1 Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted June 9, 2014 Author Share Posted June 9, 2014 so now with the carbs fitting i can begin to fill the holes up haha made a plate up for the bulkhead to try help keep its strength then made up some end plates and glued them in so with that part done i have started to build an airbox well a mould so i can make a fibre glass one using some light alloy i have at home so with that part made roughly i latherd it in some pva to start the fibre glassing but with the weather today its a bit of a waiting game haha 1 Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted June 12, 2014 Author Share Posted June 12, 2014 so while we had the gearbox out we have sorced a bzr 6 speed to hopefully be the cheaper option to make a better gear set if this doesn't work it back to the drawing board . but like anything its not a direct swap from the c56 .... for starters differnt shifters so need to modyify linkage on the side to suit oh and a plate to mount it on to my exsiting welded tubes in the floor the pelt of bits haha was bought as a manual conversion kit so have a few more parts than i need 1 Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted June 12, 2014 Author Share Posted June 12, 2014 so heres where and how the fibreglass airbox will sit with carbs heres the new brake lines i got the boys at apex to make this week as old ones would hit the sway bay and im not liking the look of the crimp so to be safe so opted for a banjo bolt setup with 45 degree bend to clear the bar Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted June 12, 2014 Author Share Posted June 12, 2014 nows it all a mater of making a water hose work re mount the coil in a differnt spot as where this all used to be has now changed with the addition of an airbox and the fcr carbs Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted July 1, 2014 Author Share Posted July 1, 2014 so time for a few updates exausts made and off to the coaters Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted July 1, 2014 Author Share Posted July 1, 2014 so had the new shocks arive and fitted them now after machining spacers to suit they should do the job it will either handle better or like a drunk camel who knows haha so c160 gear box is apart to remove the toyota lsd and fit the quaife lsd we have run in the car so far so progress haha and the airbox is all painted so just needs to be attached also had a good parcel turn up this arvo 4 brand new dunlop wets from the uk so should increase thepace in wet weather by a bit lol so things have been flat out also found a quick and easy way to save 7kg in the car buy a lighter battery !!!! managed to get ahold of a fancy battery and only weights 3kg so should lighten things up a tad bye for now 2 Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted July 30, 2014 Author Share Posted July 30, 2014 Afternoon guys been a while ..... been flat out working and spending money on this thing again haha so heres a run down so much is changing for the new season coming up in October... ooo and theres a few nice little trick parts underconstruction they will be a suprise .... currently waiting for new tarox front brake rotors to arrive from the uk so for now nots much is happing in the front suspenion area so have had the exhaust back from the coaters and have installed the system now so now for the start of the exciting part of the rear custom alloy hubs will update once fitted just got them back from the anodiser rear backing plates are painted and fitted ready to go this year we going to remove that massive hump that made our car differnet now we have a new bonnet while the other one has been signed by the guys and girls that have helped and is awaiting fittment on to the shed wall so heres the start of the new hood now also removed all the alloy from the pannels and have put carbon in its place the rear parcel tray now the doors were a pain to hold there shape so i improvised and persuaded them to shape final product of the doors so thats it for now more to come im sure 7 Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted September 7, 2014 Author Share Posted September 7, 2014 been awhile but cars taking shape new roll bars etc made brakes all fitted and bleed up almost ready for a shakedown heres the rear braking set up all complete added some more ducting to flow air into the radiator and try to seperate the air flow but cant quite see the ruber flat sitting onto of the oil cooler which is also to ramp the air into the radiator Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted October 6, 2014 Author Share Posted October 6, 2014 soooo bought a body kit for a longer front mini and ofcourse i wanted to fit it to my car hahah so had to remove 100mm out off it and yer so heres a few pictures duct tape was the key involved here to hold it all together to semi glass it together hahah so to hold it on we decided to us dzues quick and easy heres the finished product so thats how it sits while i rember hers a picture of the new setup under the hood 6 Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted October 6, 2014 Author Share Posted October 6, 2014 on the 1st of october we went down to taupo for some much needed pre testing car ran well the new brakes certainly halling the car up and the new shock asorbing the bumbs and the fcr carbs sounding sweet as the 6 speed box allowed us to run the motor high in the rev range every shift so heres a short on board video of the car now on old tires and trying to not use tooo much of the car before the season haha 4 Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted February 3, 2015 Author Share Posted February 3, 2015 cheers for now ill add some exciting new devlopments soon once i get them sorted my self myself Quote Link to comment Share on other sites More sharing options...
Miniman76 Posted April 28, 2015 Author Share Posted April 28, 2015 So been quite lately busy developing and looking at new ways to improve the car here the first of our development to try for the next round to see weather we run bigger rims next year for tires so i took the wheels of the road car as that's out of action receiving a jap power plant now got some nice 8.2inch wide slicks altho it wasn't just bolt on fit haha was when car was on the stands but modifying was necessary we had to raise guards slightly but modified the front heaps especially moving the splitter forward as you can see quite a gap to fit so out came the fibre glass and alloy now it came out ok but close enough to run a meeting like it for taupo the wider wheels do loose us clearance to the crank pulley so steering stops might go in after this last race but thats not all we have planed even removing the gear stick next season and 265mm front brakes with willwood 6 pots stay tuned Quote Link to comment Share on other sites More sharing options...
