Liam-B Posted December 14, 2015 Author Share Posted December 14, 2015 Oh page two now?! Ha, anyway, moving right along to the present and this just turned up from summit. I was not too keen on putting a cam in when I had the heads off etc, due to that becoming another potential hassle, when I really wanted to get it back together asap. Now its all bedded in I can wake the old 302 windsor up! Specs are the following : Basic Operating RPM Range:1,800-5,500 Intake Duration at 050 inch Lift: 218 Exhaust Duration at 050 inch Lift:228 Duration at 050 inch Lift:218 int./228 exh. Advertised Intake Duration:278 Advertised Exhaust Duration:290 Advertised Duration:278 int./290 exh. Valve Lift with Factory Rocker Arm Ratio:0.471 int./0.471 exh. Lobe Separation (degrees) 114 Basically its the biggest cam I can fit with a stock torque convertor, it sounds great on the youtube clips I had listened to 4 Quote Link to comment Share on other sites More sharing options...
