evilre Posted May 17, 2013 Share Posted May 17, 2013 Hi there, The other day when I was driving my 83 Mazda B1600 ute, as I was turning the horn got stuck on, so i pulled over and disconected it, problem temporary fixed. I later pulled off the steering wheel to try and figure out the problem, I found that the wire from the horn button had ripped away from the copper ring that engages the horn. I solided it back on, put everything back together, pretty easy I thought, but then tested it out and nothing, no noise at all. Im pretty crap at electronics & stuff, dont really even how the whole horn set up works, any Ideas? Yes I have checked the fuse, and yes I have tested the horn its self, no problems there. So I'm pretty stuck now. Do these have relays? had a look, couldn't find any? Any help most appreciated, Cheers. Quote Link to comment Share on other sites More sharing options...
Jase Posted May 18, 2013 Share Posted May 18, 2013 put a slightly heavier spring behind the pin that rides the copper ring and touch it up with wet an dry Quote Link to comment Share on other sites More sharing options...
