ddslancer Posted October 5, 2012 Share Posted October 5, 2012 Hi I have a 2L cortine motor in my escort production saloon. I did an oil change when I first got it going (had been sitting for 2 years). then started it once a month or so over the off season, I noticed that there was so water in the oil and was guessing it was condensation. but when I went to do another oil change during the week almost 10L drained out the sump! So I pressure tested the cooling system and found that water was coming out the sump plug....great. so I ripped the head off and checked thet gasket but its like new no breaks or anything, have straight edged the surface yet but I will, will also get the head crack tested. But what I did see is that the intake manifold and even a little bit on the head around the water feed was corroded. I could also see milky oil going down the intake ports into all the cylinders. What I was wondering is would the water be leaking past the gasket on the intake then down the bores past the rings and into the oil??? Anyone had a similar problem before? sure it may be a cracked head or block (60 thou oversize) but with how much water was draining out it needs to be a BIG crack. Also the coolant wasn't contaminated still just plain water. Cheers Quote Link to comment Share on other sites More sharing options...
Borgweiser Posted October 5, 2012 Share Posted October 5, 2012 loose head bolts? Sure that gasket was under enough compression? Quote Link to comment Share on other sites More sharing options...
Horse25 Posted October 5, 2012 Share Posted October 5, 2012 I had this problem before, It was a cracked head, but took them a few goes to find it as it was in one of the bolt holes which they were blocking up when crack testing it. Quote Link to comment Share on other sites More sharing options...
ddslancer Posted October 13, 2012 Author Share Posted October 13, 2012 got it sorted in the end was a small hole not a crack in the no2 cylinder wall leaking into the bore and past the rings, anyone in welly got a spare 2L motor they wanna sell? Quote Link to comment Share on other sites More sharing options...
