R100 Posted January 27, 2012 Share Posted January 27, 2012 Discussion here > viewtopic.php?f=18&t=31478Not much to report at this stage. Picked it up a few weeks ago.Orginally fitted with a 2.3 4 cylinder this wagon was converted to a V6 prior to 1990.The donor V6 was a 226 cu (3800) chevy v6 im insure if it was a 60 degree or 90 degree V6 as i purchased the car with no engine. Im not even sure if chev produced a 60 degree V6 with 3800cc capacity anyway. Maybe someone here knows.It comes with a declaration certificate of the conversion dated 1992.It also has a LHD permit.The transmission as far as im aware is the turbo 350 trans.The engine i will be fitting is a 4.3 liter (262 cu) from a 2001 chev blazer.It has 3800 heads fitted. Reason for the 3800 heads is because of the inlet manifold bolt pattern. You can buy aftermarket intake manifolds for the earlier 3800 but not the later model 4.3 liter.The 4.3 will be fitted with a GM471 supercharger.The supercharger is currently away getting polished.More updates as i go. Quote Link to comment Share on other sites More sharing options...
R100 Posted May 3, 2012 Author Share Posted May 3, 2012 Been working on getting the engine ready. Had to cut the sump down and modify the pick up to suit. Blower back from polishers now, just needs new bearings/seals/clearancing and reassemble. Running a 40 tooth bottom pulley 3.5" wide and 41 tooth top pulley. Using the newer 8mm pitch belt/pulleys. Not far away from dropping it in the engine bay. 1 Quote Link to comment Share on other sites More sharing options...
R100 Posted November 28, 2012 Author Share Posted November 28, 2012 Motors in the hole now. Feeling so unmotivated lately. Quote Link to comment Share on other sites More sharing options...
R100 Posted November 28, 2012 Author Share Posted November 28, 2012 Quote Link to comment Share on other sites More sharing options...
R100 Posted January 15, 2013 Author Share Posted January 15, 2013 Up for sale shortly. Wanting $5000 without supercharger set up. Although blower and manifold etc are forsale also. Will be sold with rego and wof. Need the room. Too much shit everywhere. Good beach hop cruzer Quote Link to comment Share on other sites More sharing options...
R100 Posted August 7, 2013 Author Share Posted August 7, 2013 Anyone want this ? Make an offer. Owes me way to much. Has cert for LHD and V6 conversion. Just needs exhaust done and engine mounts bolted in. Not much really but have zero interest at the moment and its taking up space. Quote Link to comment Share on other sites More sharing options...
R100 Posted August 10, 2013 Author Share Posted August 10, 2013 You know you want this. $3500 Quote Link to comment Share on other sites More sharing options...
R100 Posted September 13, 2013 Author Share Posted September 13, 2013 Someone buy this. Make a serious offer. It's just taking up space. Quote Link to comment Share on other sites More sharing options...
73crownwagon Posted February 3, 2014 Share Posted February 3, 2014 i sapose i should own up to now owning this fine piece!  feck yes! my first merican car! plan is to put it all back together and wof reg for now 6 Quote Link to comment Share on other sites More sharing options...
73crownwagon Posted February 3, 2014 Share Posted February 3, 2014 i sapose i should own up to now owning this fine piece!  feck yes! my first merican car! plan is to put it all back together and wof, reg, burnouts 1 Quote Link to comment Share on other sites More sharing options...
73crownwagon Posted February 8, 2014 Share Posted February 8, 2014 Andrew dropped the car off on Waitangi Day. Just been going over what stuff I need get it back together. And lining up my gillies for maximum pinging! Quote Link to comment Share on other sites More sharing options...
73crownwagon Posted March 19, 2014 Share Posted March 19, 2014 Been working on the vega every night since nats, shit be getting done! Too much to list but hopefully turn key Sunday and send to Woolf mufflers Monday sometime. Then if everything goes well take it to beach hop next weekend!!!! 5 Quote Link to comment Share on other sites More sharing options...
73crownwagon Posted April 13, 2014 Share Posted April 13, 2014 http://m.youtube.com/watch?v=yQuS9mBLijg 2 Quote Link to comment Share on other sites More sharing options...
73crownwagon Posted April 13, 2014 Share Posted April 13, 2014 so i basically have very little left to do before until shes driveable, yesterdays start up made clear that i need correct auto trans cooler hosing not jimmied up copper which made a mess of my driveway so ill sus that from hyrdalink today. needs front have of exhaust made up and the wiring tidied up a small amount. there will be a few small asshole things that will pop up for sure but if im lucky ill take it away for easter 2 Quote Link to comment Share on other sites More sharing options...
73crownwagon Posted April 24, 2014 Share Posted April 24, 2014 Made the exhaust today 5 Quote Link to comment Share on other sites More sharing options...
73crownwagon Posted May 4, 2014 Share Posted May 4, 2014 Ok so shit be getting done! Motors in, pipes on. Took for first drive. Which threw the gillie belt clean off because had them to pinging with the alternator not very lined up with the other belt drives. It seems to be using far to much gas at the moment so thinking I might have to re jet for the v6 which I'll look into this week. Also want to bleed brakes before warrent. Also sunk 2" temp gauge and oil pressure gauge into original dash to try keep it clean inside and the temp guage was in stupid American degrees. Was on the beach yesterday and found some knuckle dusters in the mud flats lol thinking about making a shifter out of them since mine doesn't need a button on top. Quote Link to comment Share on other sites More sharing options...
73crownwagon Posted May 4, 2014 Share Posted May 4, 2014 Also does anyone have any Chevrolet badges that may look the part on this? Vega never had any apart from vega on the front which I don't have and will track one down. But wouldn't mind having maybe a chev bow tie on the front and a Chevrolet on the back Quote Link to comment Share on other sites More sharing options...
Popular Post 73crownwagon Posted May 13, 2014 Popular Post Share Posted May 13, 2014 So had a ball ache with the car using a shit ton of fuel. with the help of reteps fuel pressure gauge we determined the fuel pump was garbage and maxing out the 9 psi gauge when the carbs only made for maximum of 6.5 wen with the reg tightened right in still way to high! So that shit got tossed in the bin and new pump installed Oh and then this happened! 14 Quote Link to comment Share on other sites More sharing options...
73crownwagon Posted May 15, 2014 Share Posted May 15, 2014 In my warrent sheet me wof man wrote I needed to look at my brake pads and front wheel bearings so true to my word I looked into them. Surprisingly went to segedins and one of there stockists had brake pads for vega/monza in stock so 24 hours later they were installed. And wheel bearing packet with new grease and tighten up. 2 Quote Link to comment Share on other sites More sharing options...
Popular Post 73crownwagon Posted May 21, 2014 Popular Post Share Posted May 21, 2014 10 Quote Link to comment Share on other sites More sharing options...
