Mfordy’s Escort Rebuild
mfordy
  • 4 months later...
This has got to be the slowest build in history!..
Car's back from panelbeater de-rusted and new floor.
Rollbar and seat mounts sorted
Dummy fitting of Type E gearbox and single piece driveshaft
Front suspension nearly sorted. Just missing decent sway bar, green tie rod ends and quick rack
Off to the painters next $$$$ :shock:
  • 3 months later...
A bit more progress..
Decambered with extra leaf.
And one of these with a 4.44 diff I'm rebuilding at the moment :badgrin:
New manifold so I can retain the brake booster
Front suspension still ongoing. OEM TCA's are shit!...
Gearbox rebuilt and mod completed
Finally found some decent UK cast TCA's. Taiwanese knock offs (left) are so bad, you can't fit a sway bar nolathane bush as the casting hole is offset
POR Caliper paint is good stuff. Mintex 1166 pads to fit.
Competition linings from Autostop - not sure how good these are going to be. All new cylinders and mounting hardware
Group 4 steering coupling
  • 4 months later...
Starting to get the engine back together.
Didn't really know what spec the motor was but stoked to find a well sorted head (albeit with a bent No. 2 exhaust valve) - Stage 3 spec Big valves, porting etc
Added steel shaft, posts and spacers. Resurfaced cam with duplex adjustable chain/sprocket. Steel banded head gasket as evidence of a small leak between 2 and 3 when pulling apart
ARP bolts/studs. A little more work to the rods and new rings. Custom oil control plate
To combat the oil surge issues, I'm spending some serious $$$ getting a proper gated/baffled sump made. The old winged sump was an engineering disaster and has been confined to the bin.
Also waiting on the gearbox which is getting modified for larger bearings etc.
Engine went fairly well before the rebuild, so will be interesting to see how well it goes now....
  • Like 8
  • 8 years later...
