camo_78 Posted February 28, 2011 Share Posted February 28, 2011 anyone know how hard it is??just dropped my worked 2litre pinto and 5 speed into my new mark 5 cortina,and every time i engage reverse it crunches like f***ery,even when the clutch pedal is almost through the floor.all forward gears are fine,its just reverse .any ideas peoples?? Quote Link to comment Share on other sites More sharing options...
escorted Posted February 28, 2011 Share Posted February 28, 2011 Probably Cheaper To get another one? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 28, 2011 Share Posted February 28, 2011 your clutch is probably draggin slightly. reverse is the only gear on these without a synchro. the synchro will create enough drag to slow the clutch mechanism down. maybe even your spigot bearing is a bit rumbly, causing this. check your clutch freeplay and adjustment and see if it'll release more. alternatively if you swung the box off the clutch disc at all, it may have a slight warp in it. running off true by about 3 thousands of an inch can cause issues with releasing. 1 Quote Link to comment Share on other sites More sharing options...
camo_78 Posted February 28, 2011 Author Share Posted February 28, 2011 your clutch is probably draggin slightly. reverse is the only gear on these without a synchro. the synchro will create enough drag to slow the clutch mechanism down.maybe even your spigot bearing is a bit rumbly, causing this. check your clutch freeplay and adjustment and see if it'll release more. alternatively if you swung the box off the clutch disc at all, it may have a slight warp in it. running off true by about 3 thousands of an inch can cause issues with releasing. spigot bearing was brand new when i fitted 5 speed(engine was originally auto).clutch cable is as tight as i can get it (cortinas and their stupid pedal adjustment setup ),im thinking the last option of warped clutch disc could be possible,when i originally fitted the 5 speed i did it on my back lawn lying under the car so knowing murphy i managed to f**k it up.thankfully ive got a 205 motor sitting in my garage with the escort van and it has a spare clutch fitted,so may be time to swap the clutches over.thanks for the advice though,will report back when i can be arsed dropping the box out,lol.i should really do a build thread too,lol Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted February 28, 2011 Share Posted February 28, 2011 just 'borrow' a synchro form a forward gear (so when you're about to go for reverse, ease the gearstick into something like, 3rd, then hoon back into reverse before the 'box spins up again. I have to do that on my citroen coz the 'rebuilt' clutch I got for it is shithouse and wont release. Quote Link to comment Share on other sites More sharing options...
camo_78 Posted February 28, 2011 Author Share Posted February 28, 2011 just 'borrow' a synchro form a forward gear (so when you're about to go for reverse, ease the gearstick into something like, 3rd, then hoon back into reverse before the 'box spins up again. I have to do that on my citroen coz the 'rebuilt' clutch I got for it is shithouse and wont release. i like your thinking,shall try it later when i fire the beasty up as its not currently road legal and slightly loud(4-1 extractors is all it has for exhaust at the moment,lol) Quote Link to comment Share on other sites More sharing options...
mrk5tina Posted January 14, 2014 Share Posted January 14, 2014 You woulnt know or have a clutch peddle box laying round? ? Quote Link to comment Share on other sites More sharing options...
