efp0wa Posted May 6, 2010 Share Posted May 6, 2010 Hey all, L200 4g63; is it the same as a L300 4g63/ will it bolt in? Apparently sumps and wiring may be different, can someone confirm please? I've purchased another 4g63 carby engine from a L200, I havn't removed the engine from my L300 yet to check any differences so thought I would ask on here. Quote Link to comment Share on other sites More sharing options...
fuel Posted May 6, 2010 Share Posted May 6, 2010 as far as I know yes the sump on the L200 is different, well at least it is on the 4WD versions of the L200. But I'm sure you could just swap your L300 sump and oil pickup over easy. Inlet and exhaust manifolds should be the same, if not they can be easily swapped. Wiring - what wiring? Alternator is in the same position, there's only a wire or two going to the carb and the oil pressure sensor would be in the same place too. Quote Link to comment Share on other sites More sharing options...
efp0wa Posted May 6, 2010 Author Share Posted May 6, 2010 That's what I was assuming. Its from a 2wd L200. Things should swap over easy peasy right? (if required) Quote Link to comment Share on other sites More sharing options...
WildPlumDx Posted May 8, 2010 Share Posted May 8, 2010 pajeros and 4wd l200 are different so i wouldn't be surprised if the l300 is diff again Quote Link to comment Share on other sites More sharing options...
WildPlumDx Posted May 8, 2010 Share Posted May 8, 2010 as for sump pick ups swapping over i hope so as i gotta do the same thing at some stage but i honestly would almost guarantee they would Quote Link to comment Share on other sites More sharing options...
