HighLUX Posted January 22, 2010 Share Posted January 22, 2010 Have been playing round with fitting hiace brakes and hubs to the townace, only problem is the inner bearing on the hiace hub is larger than the townace bearing, can the seal and bearing be pressed out and a new bearing of suitable size be pressed in with no problem so the hubs will fit on the townace spindle? Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted January 22, 2010 Share Posted January 22, 2010 http://www.skf.com/portal/skf/home/prod ... link=first use the search function on there, will tell you if they make a bearing that size. almost guarantee they will smack that on and your awaayyyye Quote Link to comment Share on other sites More sharing options...
HighLUX Posted January 23, 2010 Author Share Posted January 23, 2010 Exactly what I needed to hear thanks Quote Link to comment Share on other sites More sharing options...
