crusty_rusty Posted December 2, 2009 Share Posted December 2, 2009 hey boes ive got a 4g62t which is going to run a multipoint injected custom mani and im just wanderin what you might recomend in the way of injectors. im thinkin sum standard evo ones would be the go but iv go sum 1800 non turbo mitsi ones rated at 210cc would those do the trick or should i go bigger? cheeeerrrrz! Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 5, 2009 Share Posted December 5, 2009 id say about 400, i think the gsrs run 390 so 210 would be asking for trouble/metled pistons Quote Link to comment Share on other sites More sharing options...
fuel Posted December 6, 2009 Share Posted December 6, 2009 yep as above. non-evo VR-4 run 450cc blue-top injectors which are cheap enough to find, but would probably be worth finding some yellow-top evo 510cc injectors, you can often pick them up for around $200-250. Which manifold are you running? You can just grab a manifold off a SOHC 4G63 Galant/Chariot or even a Hyundai Sonata and then just swap the throttlebody over to the other end. Quote Link to comment Share on other sites More sharing options...
