ke25_ Posted April 23, 2009 Share Posted April 23, 2009 Project Discussion : viewtopic.php?f=18&t=18274 I Brought a 1984 starlet with a genuine 65km on the clock about 3 months ago. I had to pull the factory 4k engine out to put into a car I sold, so now ive decided to put a ca18det into it, I managed to find a mint engine package for a mint price! heres some picks The starlet The engine The wheels and tires, rays engineering 15x6.5 + 195/45r15s I am just waiting for my flatmate to get rid of one of her peices so I can have some shelter under carport to start making it all happen, slowly gathering bits and peices still got 8 months no licence so in no real hurry, I should realistically have it on road before xmas, intended mods at this stage, t28 gtir turbo vr4 front mount intercooler vr4 injectors electronic boost control 500hp walbro external pump and surge tank 3" exhaust z32 airflow meter chipped ecu This is a setup a couple of my mates run and on 15psi good for a reliable 250rwhp+ish hilux lsd diff or similar u13 bluebird discs / mr2 twin pot pot calipers up front 2 race seats no back Quote Link to comment Share on other sites More sharing options...
ke25_ Posted September 18, 2009 Author Share Posted September 18, 2009 Well its been a while since an update, Iv now shifted places so have somewhere sheltered to work on my starlet, everything I dont need has been removed, all bolts were cracked for the 1st time .There is NO rust, the car is pretty much flawless , The engine loom has been removed to be cut down and wired into starlet, gearbox split from motor reveals a mint as factory nissan clutch but I will be replacing this with a heavy duty exceedy in the next few weeks, the motor is ready to go straight in, then I will have so cut a hole further back in the tunnel for the shifter and modify the gearbox crossmember to suit, then diff upgrade will begin, couple of pics I haven't even cleaned the engine bay I will be taking extra extra care to keep all paint intact and not chip or scratch while motor is being installed got wheels finished and tyres on them, bit of modivation Quote Link to comment Share on other sites More sharing options...
ke25_ Posted November 20, 2009 Author Share Posted November 20, 2009 Engine is now in, fits nicely and everything is sort of where it needs to be, I get one of these next week so ByeBye brake booster, hello wilwood reverse mount pedal box, custom frame to mount into kp and 3x wilwood master cyls, 1 for front brakes 1 for rear and one for clutch. I need some remote reservoirs and to mount them in wiper motor compartment, The engine has already had genuine nissan cambelt, clutch, water pump, thermostat etc etc so i got an extra $400 valuve out of my engine, so its ready to go Wiring loom has been heavily chopped down by a ca18det into datsun guru and will be stitched into car hopefully this week next on the to do list cut hole for shifter and mount gearbox fuel lines crank pully machined down for radiator clearance mount pedalbox (arrives next week) + brake lines then dash back in once wired Quote Link to comment Share on other sites More sharing options...
