nobumps Posted March 26, 2009 Share Posted March 26, 2009 If your spraying clear you wont need to flatten your base, get your mettalic base spray that as per usuall, then spray 2/3 clear coats then on your last 1/2 coats of clear thats when you add your flattning agent, you only need a small amount otherwise it will go to grey,(try a test panel first), try your best to miminize overspray as stated before, you wont beable to cut it out, Ive done the same with a champagne met and it came out mint Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 26, 2009 Author Share Posted March 26, 2009 Ahh so you just did the clear. So it has a glossy feel so easy to clean etc but looks dull and satin. Got any more pics of yours other than proj thread? Of whole panels? Or have ya just done jambs at the mo?. Gaz Quote Link to comment Share on other sites More sharing options...
nobumps Posted March 26, 2009 Share Posted March 26, 2009 yup so its fully protected, can clean etc, its not dull its just got a nice sheen not a shine, Ive only done jams etc Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 26, 2009 Author Share Posted March 26, 2009 Sweet cheers amn, think going that way is the way to go. Was trying to aviod clear as im painting in garage and its just another few coats to get dust and shit in. But I will manage. Gaz Quote Link to comment Share on other sites More sharing options...
nobumps Posted March 26, 2009 Share Posted March 26, 2009 just wet the shit out of the walls floor etc and keep it wet youll be all good Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 26, 2009 Author Share Posted March 26, 2009 Doesnt that put moisture in the air tho? Gaz Quote Link to comment Share on other sites More sharing options...
NewGuy Posted March 26, 2009 Share Posted March 26, 2009 When i primered i wet the ground then brushed it down then sprayes Quote Link to comment Share on other sites More sharing options...
Insani-T Posted March 26, 2009 Share Posted March 26, 2009 Doesnt that put moisture in the air tho?Gaz Paint Booths have water flowing through them all the time. Everyone I know paints like that when they doing it at home. Its all gravy Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 30, 2009 Author Share Posted March 30, 2009 Sweet will do then. Will also crank the heater. Hope the tiny gge isnt to small. More updates when push comes to shove. Quote Link to comment Share on other sites More sharing options...
