allan Posted March 23, 2009 Share Posted March 23, 2009 i pulled apart my pitty carb to give it a clean up and put it back on but now when i start it fuel comes out the top any help? cheerrs Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted March 23, 2009 Share Posted March 23, 2009 float valve bei. will be sticking open or a bit missing. che Quote Link to comment Share on other sites More sharing options...
allan Posted March 23, 2009 Author Share Posted March 23, 2009 sweet man is that that plastic thing with a pin in it sortof? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted March 23, 2009 Share Posted March 23, 2009 you take the bowl off the bottom and there's a floaty looking thing in there. under that, if you pop the pivot pin off then up in there somewhere is a needle valve. you've either lost the spring, spacer, or the needle itself, or, it's not seating properly becasue the float isn't pushing it up enough or there's shit in there stopping it closing. either way you should be able to work it from there. post back with what you find! good luck Quote Link to comment Share on other sites More sharing options...
