Nate-R32 Posted January 5, 2009 Share Posted January 5, 2009 Hey guys, I am currently helping a mate build a KP61 skid car. Basicly it is a standard 4K in a bare shell with a seat and steering wheel. We have the motor starting and running but not yet holding an idle but that is easy stuff, We need to get the alternator running but that is prooving a nightmare. Because we have started the wiring from scratch (as it is push button start) we don't have the 3 pin plug for the alternator, or know what each of the 3 wires, or the bolt terminal do or if there is any more i havent seen. Has anyone had any expecience with this or am I pushing shit up hill trying to wire it myself? Nate Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted January 6, 2009 Share Posted January 6, 2009 if you can track down a wiring diagram it should be easy as. You'll likeley need a regulator too, I don't think the starley alternators were internally reg'd. Quote Link to comment Share on other sites More sharing options...
l1ttle_d3vil Posted January 6, 2009 Share Posted January 6, 2009 where are you located? i just pulled this wiring out of my car for an engine conversion as im running an internally regd alternator. also have the old external reg if you don't have it, plugs etc. Could probably track what most of the wiring does. From memory though all 3 wires on the actual alternator plug went to the reg... Quote Link to comment Share on other sites More sharing options...
QCADTA Posted January 6, 2009 Share Posted January 6, 2009 internal or external regulator? Quote Link to comment Share on other sites More sharing options...
l1ttle_d3vil Posted January 6, 2009 Share Posted January 6, 2009 99% sure it would be externally regd, unless its been modified. here is the wiring off a 3K, should be all the same if yours is externally regd. I have these plugs and the regulator if you need them. the bolt terminal will also be a 12v+ BATT connection, won't charge without it. IF it is internally regulated, it should only be 3 wires + the bolt terminal which will be batt still. other 3 wires would be 12v+ batt, 12v+ ign and warning light. Quote Link to comment Share on other sites More sharing options...
QCADTA Posted January 6, 2009 Share Posted January 6, 2009 or use google if that doesnt help. easy to find plenty of info http://www.rollaclub.com/board/?showtopic=17827 Quote Link to comment Share on other sites More sharing options...
Nate-R32 Posted January 6, 2009 Author Share Posted January 6, 2009 It has 3 pins in the formation shown on above pic, so one would assume i require a regulator. For starters I assume I connect the bolt on terminal to the battery + using heavy-ish cable, How much you want for plug and regulator? Quote Link to comment Share on other sites More sharing options...
l1ttle_d3vil Posted January 6, 2009 Share Posted January 6, 2009 PMd Quote Link to comment Share on other sites More sharing options...
