MESDUP's 79 323 Hatchback
MESDUP
ok so i thought i should start a project thread as it keeps a good timeline of your build etc
Anyways i parted with my bongo on the 21st of june and recieved a 1979 323 4 door hatchback rolling body.
As i plan to have this on the track i will be keeping it all fairly basic in the looks department and focus on the go.
What it has:
Hilux 4:4 LSD, Bluebird discs
2 series 4 oilcoolers welded on top of each other with 3 motor bike fans
3 core radiator with 2 therma fans on the front
What i have bought for it so far:
10ib billet flywheel
5 puk clutch
1 ton billet pressure plate
W58 supra box, adapter to rx3 bellhousing
steel selectors
Bosch 910 fuel pump, carter 4070 lift pump, custom made alluminium surge tank
1/2" fuel lines
efi hardware 50mm ida style throttle bodies, 4 550cc injectors, microtec ltx8
will be running a 13b with rx8 rotors.
will have more pics later
hmm, need to find my proper camera.
anyways heres my new rear bumper, won some chrome end caps for a front bumper on trade me the other day so waiting on them to show up, also have a brand new(still in original mazda box) front chrome bumper, so just need to put new end caps on
picked up my new adjustables today
custom made surge tank, 16mm to main pump, 10mm from carter lift pump, 8mm rail return and 12mm return to tank
From L to R:
Fuel filter ($70) bosch 910 rated at $350hp 130 litres per hour (at 5bar) and Carter 4070 to be used as a lift pump
B&M line locker installed with new lines (is not really a line locker when used in this application, but just to shut off rear brakes)
New Racepro Rp2 driver seat, Racepro Arrow 101 passenger
And the paint:
Peugot Gris chateau aka dark gun metal grey
ok so dont all screw your noses up about the tail lights at once :lol: , this was/is a pretty notorious hatchy so still gona keep them on as it wont be the same car without them, if you get what i mean.
anyways got my camera so now have better pics, heres my new rear bumper
the custom 2x series 4 7 oil coolers welded one on top of the other should keep it cool
got brand new, NOS bumper 2day and also my 2nd hand endcaps turned up so will use this on the front
My EFI hardware 50 mm throttle bodies, the intake manifold give away what i will be running so will post a pic up of housings 8)
Picked up my gilmer belt drive tonight, off to tauranga tomorrow to pick up my gbox as its had steel selectors fitted, turns out my W58 is a rare high strength model with a heat treated main shaft :D .
While im over there i will be dropping my rx3 bellhousing and gilmers off to get polished
So it turns out my rx3 bellhousing is a bottom mount starter twin dizzy item so to me it means its useless as it wont bolt up to back of my motor.
Anyways picked up my gearbox from TGA and its been fitted with its steel selectors and dropped my gilmers and chrome end caps off to get polished
picked up a set of M&H slicks, originally off the 323 so perfect fit
Tyres are 235/60/14 and rims are 14x6
also autometer sport comp oil pressure, temp, water temp and tacho with memory setting
also picked up a locked hilux diff with the perfect ratio to match the box
this is the exact same package that was used to get this car running a 12.1 so crossed fingers i can keep up with those times
puchased a pair of 675cc & 960cc injectors to replace the 4 550cc ones that i have
Finally got my rotating assembly up to auckland balancers
Decided that scotching the engine bay wasnt enough so spent a few hours in there with a festo sander
todays purchase!
Short shifter kit @ $250
That now bumps up the cost of my complete gearbox to $2050 :shock::lol:
heres a little spiel about them:
Brand New short shifter to suit all the Celica and Supra W series gearboxes, W50, W55, W57, W58, W59 and R154 RWD models. Will suit both the steel case and aluminum models. This new short shifter reduces the movement of the gear lever by at least 50% both forward and back and from side to side allowing a quicker more positive shift right through the range.
Unit Comprises
New Hard chrome shift lever (shortened 50mm with original thread)
New CNC machined high tensile aluminum housing
New CNC machined 4340 high tensile steel pivot
New shifter seat bush
New Ball seal
New stainless steel bolts
Written 12 month warranty on materials and workmanship
A few more recent purchases
custom made Camber tops for $300
sent these away to get chromed....$267 dollars later
dunno if i will bother getting anything else done
currently sanding the floor
engine bay primed but still going fix a few things yet
