10Speed Posted November 29, 2014 Author Share Posted November 29, 2014 Things are snug 5 Quote Link to comment Share on other sites More sharing options...
Popular Post 10Speed Posted November 29, 2014 Author Popular Post Share Posted November 29, 2014 12 Quote Link to comment Share on other sites More sharing options...
10Speed Posted November 29, 2014 Author Share Posted November 29, 2014 all fitted in, with an additional oil cooler and fan, no cuts to the body... however a test run with out boost at this point has revealed a leak between head and cylinder... fixing this means removing the engine and getting the head fly cut... which means the new engine won't be debuting at Meremere next weekend )-; Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 1, 2014 Author Share Posted December 1, 2014 so in a little more detail... currently has screamer pipe, might be legal this far back? also has muffler, but I also have a dump pipe to replace this with when going to the track has fuel pressure reg and guage in the crappiest place ever - but kind of works has a wide drop sump, total oil capacity is about 6l now, also provides a handy return point for post turbo oil also has a proper oil filter, first time I have had one of these on a vw it also has one of these bolted underneath... 9 Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 16, 2014 Author Share Posted December 16, 2014 so the last piece of the puzzle arrived this morning... programmable ignition, should work a bit better than a locked distributor 4 Quote Link to comment Share on other sites More sharing options...
Popular Post 10Speed Posted December 19, 2014 Author Popular Post Share Posted December 19, 2014 so it's all done, bar some tidying up... have taken it for a proper drive this morning, and probably barely used more the 1/8th throttle, it feels fast... pretty pleased 20 Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 20, 2014 Author Share Posted December 20, 2014 Well that was short lived... driving a long the motorway making blow off value noises.... waiting at the lights at the off ramp with the clutch in... release the clutch and it seems gearbox has locked up... manage to push it to a traffic island (with the help of an Impala driver).... sigh.... off to google the symptoms now... Quote Link to comment Share on other sites More sharing options...
10Speed Posted December 20, 2014 Author Share Posted December 20, 2014 hmmmm... the transmission has freed up this morning... heat related problems maybe... 1 Quote Link to comment Share on other sites More sharing options...
10Speed Posted January 21, 2015 Author Share Posted January 21, 2015 still having transmission issues (cheers for the escort home from burgers Chris and Tara), new trans is on the way - will hopefully be here in time for OS trackday... in the meantime I have been talking to an old school formula vee racer/builder guy about how they made their cars handle, as they use the same front suspension that I have. And he has kindly sent me a set of camber bushes and hand written instructions on how to fit them These will take the front end from positive camber into negative camber... 5 Quote Link to comment Share on other sites More sharing options...
10Speed Posted February 4, 2015 Author Share Posted February 4, 2015 some 'custom' brake bits arrived... ugly disks and caliper adapters to take mk2 golf callipers 5 Quote Link to comment Share on other sites More sharing options...
10Speed Posted March 3, 2015 Author Share Posted March 3, 2015 Quote Link to comment Share on other sites More sharing options...
10Speed Posted March 3, 2015 Author Share Posted March 3, 2015 so the VW isn't going to make it to Nat's track day... but on the bright side I'm taking the opportunity to tidy up some stuff, starting with powder coating the cooling tin 3 Quote Link to comment Share on other sites More sharing options...
10Speed Posted March 11, 2015 Author Share Posted March 11, 2015 powder coating of cooling tin and induction bits done 4 Quote Link to comment Share on other sites More sharing options...
Popular Post 10Speed Posted March 21, 2015 Author Popular Post Share Posted March 21, 2015 Proof of concept looks ok, though might quit using the old nokia screen and try to find a similar sized colour lcd for slightly more stealth... originally looked more like this 14 Quote Link to comment Share on other sites More sharing options...
10Speed Posted June 29, 2015 Author Share Posted June 29, 2015 unsure how much sense this pic will make to most... but the brackets to hold the IRS are in, as well as the irs arms, as well as the irs gear box, as well as a chassis brace (axels are still to be added) this pic is a bit more self evident.. 4 Quote Link to comment Share on other sites More sharing options...
10Speed Posted June 30, 2015 Author Share Posted June 30, 2015 hmmmm my rear wheels no longer fit... IRS has a wider track... (kind of knew that was going to happen) http://www.alibaba.com/universal-wheel-arches-promotion.html 1 Quote Link to comment Share on other sites More sharing options...
10Speed Posted July 1, 2015 Author Share Posted July 1, 2015 new rear brakes vs old 4 Quote Link to comment Share on other sites More sharing options...
10Speed Posted July 2, 2015 Author Share Posted July 2, 2015 some research I should have done ages ago... rear track early swing axle 1288mm rear track late swing axle 1300mm rear track irs 1349mm the new drums also add 2mm to the track, but bottom line is the rear track is 63mm greater than it used to be... beetle rear control arm I have heard rumors that clever men have been able to narrow these 25/29mm between the bearing carrier and the spring plate mount so that might be a possibility in the future.. Quote Link to comment Share on other sites More sharing options...
10Speed Posted July 6, 2015 Author Share Posted July 6, 2015 at least the new wheels fit (the dust caps on the front wheels do need trimming) 5 Quote Link to comment Share on other sites More sharing options...
10Speed Posted July 6, 2015 Author Share Posted July 6, 2015 and the coloured in tinware still fits the engine 3 Quote Link to comment Share on other sites More sharing options...
