RekeMeke's 1975 Datsun 240K (KHGC110)
Requiemk
Project Discussion - http://www.oldschool.co.nz/phpbb/viewtopic.php?t=12419
So i finally acquired the c110 :D
The body is aws condition no visible huge dents paint is a bit rough but other than that great. There is one big spot that needs new steal and few other possible areas due to small amount of work will keep it standard colour for the time being (this will most likely change)
It still has the brake boost intact and brakes seem to work fine which is a positive.
All chrome trims are either on the car or in the boot, no badges bar a datsun tail light one.
Came with a boss kit attached (no steering wheel) Solex door locks and munroe gas shocks.
The Plans:
Engine: RB25DET, frontmount (hidden) screamer pipe is a must :)
I have acquired a RB25DET from work in need of a rebuild needs new pistons rings possible rebore etc Head is fine only thing that it is missing is the turbos ill try pick up something cheap but if money is good will try to run something like to4e or similar.
RB20DET Gearbox or similar rb30s are the same i think but will need to do research.
Brake upgrade in some form
Then will try go for cert/warrant/reg
I'll be buying nothing unnecessary to get it on the road until then
I hope....
Anyway enough writing, PICHURS!!
All of the pictures here http://s200.photobucket.com/albums/aa28 ... arts/C110/
  • 3 months later...
Finally got it to my permanent place of living yesterday so work has begun :D
Stripped car down today
-all engine bay accessories
-all lights/trim/chrome.
-interior minus dash
90% done removing sound deadening on floor.
Purchasing paint stripper this week and acquiring use of sand blaster within next few weeks taking whole car back to bear :lol: metal.
Seems to have no hidden rust bar the main area, few areas am yet to check that have bog in them.
Current plans are to pick up 260c/240c for engine and drop l26 in it for time being. and get all body work done/painted in unknown colour most likely silver.
Near future will be to build coilovers all round for it.
Small update of what has been cut out, back quarter has been sanded back as well as half of the roof. My sunday hole car should be sanded back to stage where its ready for primer.
rust on the outside in last picture wasnt even bad on outside but could see the damage underneath so cut out an access panel for some por 15 :D
Made templates of new steel will get make them up tomorrow. Was going to take out all springs today but struts were being a cunt and top nut wasn't coming off so dropped the hole car down to ideal ride height, i recommend it to anyone ups motivation 10 fold.
This has also solved my problem of whether to flare or not, NOT :D
Done massive shed clean out the other week so 110 could fit in take over garage. ALot of progress been happening. Decided to bare metal it so guards have been done, sills various other areas.
ON axle stands for new bushs/nolathane? (to hard?) in front.
  • 4 months later...
engine bay all prettied up with colour of choice
Ill lay down first base coat then painter will finish things off for lush paint.
Its all stripped underneath, boot, inside etc and re undersealed.
Suspension all stripped and replaced bushes where needed and por15'd up.
rb25de sitting in carport as engine of choice. itbs cams etc. keen to beat 10-5 :P
Sweet bullet point type update, cbfd making paragraphs
Thought id make a brief list I am hoping to get done/organized in next month
-make extractors
-turret rear for coilovers
-organize wheels for it, Hamish….. haha
-wiring started
-mount bucket seats (yet to be purchased)
-get flange made up for throttle bodies to inlet
Getting stressed about getting ecu out of the way (and everything else still to be done) cause i see it being a cunty job which will end up taking a longgggggg time, which i dont have if i want it rolling for os nats in march
edit-old picture but update lacks picture so needs to roll something
  • 10 months later...
