eke_zetec_RWD Posted November 18, 2012 Author Share Posted November 18, 2012 finished ready to grind! 1 Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted November 29, 2012 Author Share Posted November 29, 2012 a few action shots of the cam building process for ya 2 Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted December 16, 2012 Author Share Posted December 16, 2012 spent this arvo assembling the head and skimming the turbo manifold. just need to profile cut a manifold gasket and put it all back into the car tomorrow night! 1 Quote Link to comment Share on other sites More sharing options...
Guest eke_zetec_RWD Posted March 25, 2013 Share Posted March 25, 2013 shit, no updates! well its running. and i tell ya its pretty good! havnt dynoed it yet though. bit more lag but loads more top end and wheel spin! 1 Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted May 21, 2013 Author Share Posted May 21, 2013 no more leaky melty sticky joiners! Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 16, 2014 Author Share Posted January 16, 2014 had to re-position a valve, some how it was quite a bit out! all back together now. i also made new cam bearings, from phosphor bronze. the white metal ones dont last with the roller cam - too much load. i also made the bearings wider than the towers since the journals on the cam are wider. this will help them last longer. you can see in the pic the bronze bearings hanging out. i also added the straps over the cam towers - its a common thing for big cams to cause the towers to snap off. 9 Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 18, 2014 Author Share Posted January 18, 2014 On dyno today, when pretty good! 243kw atw in new school tems thats 20 psi tapering down to about 18psi up top. its a big up and down as i need a stiffer wastegate spring and was hard to get the boost to stay up. if i get a new spring and hold it at 22psi the whole way it should be around the 250 to 260kw mark id say. 7 Quote Link to comment Share on other sites More sharing options...
71Chev Posted December 21, 2017 Share Posted December 21, 2017 Hi, what fuel was that on? Cheers, Phil 2 Quote Link to comment Share on other sites More sharing options...
