1300 escort engine run in
escort mk1
have done a full overhaul on my 1300 hundred and just started her up. she sounds mint and revs good but will only hold a idle if the choke is on. pretty sure its something to do with the air/fuel mixture. what should i try? it aslo splutters fuel out the carby as i dont have a air filter on while im working on it. ive reset the timing manually but i cant use a strobe light cause i cant get a good idle, it has a new coil, leads points. theres plenty of fuel getting pumped in. any help would be great.
