R100 Posted October 13, 2007 Share Posted October 13, 2007 Just picked this up the other day. 1973 HQ Belmont with 151,000 ks. Genuine 1 owner car from chch. 3 speed manual 6 cylinder.Not sure on my exact plans for it yet. But im sure ill think of something.Hard to find these now days in good nic.Discussion thread here > viewtopic.php?f=18&t=23356&p=543294#p543294 Quote Link to comment Share on other sites More sharing options...
R100 Posted November 12, 2007 Author Share Posted November 12, 2007 I stuck a set of boyd coddington 20's on it and slammed it. please excuse the poor quality pixt fone images. Quote Link to comment Share on other sites More sharing options...
R100 Posted November 28, 2007 Author Share Posted November 28, 2007 heres another better quality picture, still not very good tho. 1 Quote Link to comment Share on other sites More sharing options...
R100 Posted March 14, 2008 Author Share Posted March 14, 2008 Been busy buying parts for my project. Went to rarespares in Chch and got as many new parts as i could get, including Grill, headlight surrounds FULL rubber kit, new lenses front and rear, new arm rests, monaro door mirrors. Also bought a new radiator and fan scroud Got a low K 1997 VS V8 engine and auto trans, converting the 3 on the tree manual to auto on the tree. Got a brand new Terra Charger supercharger kit that increases the power by around 60% Will be off to the paint shop as a bare shell and built up from there. 1 Quote Link to comment Share on other sites More sharing options...
R100 Posted January 21, 2010 Author Share Posted January 21, 2010 Its been a while but have started work on the HQ again. Should get some major progress done over the next few months. Will get air suspension, tubbed rear, new diff with 4 wheel disc brakes. Quote Link to comment Share on other sites More sharing options...
R100 Posted May 28, 2010 Author Share Posted May 28, 2010 Because the wheels are so wide in the rear (20x10") they hit on the inner guards when driving on uneven ground, ie; driving down a driveway on an angle. I also want to get the car to sit real low aswell as be practical to drive on long trips. The only way around this was to tub the rear and fit a set of airbags. The floor above the diff has also been raised aswell as "c notching" the monocoque factory chassis rails. There has also been some steel removed from under the seat to allow the driveshaft to clear. Not sure on the type of diff that will be used, but its looking like a 9" as i can choose the exact ratio i want. Quote Link to comment Share on other sites More sharing options...
R100 Posted May 28, 2010 Author Share Posted May 28, 2010 The same sort of treatment is being done to the front, after my fabricator chopped the factory upper and lower wishbones up it was decided that its easier to fabricate a new set. These along with a pair of 50mm drop spindles will enable me to get the chassis "laying frame". A small part of the front chassis rail was needed to be sectioned to allow for the steering to clear. Quote Link to comment Share on other sites More sharing options...
R100 Posted July 7, 2010 Author Share Posted July 7, 2010 Airbags are in, 9" diff has been shortened and fitted. Custom front wishbones fitted. Car sits 1" off the ground on bump stops. It can be driven this low as well ! 20x10" boyds sit nicely under rear arches for maximum slamage. Track front a rear has been narrowed to allow wheels to tuck right up and steeering to turn lock to lock. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post R100 Posted March 21, 2014 Author Popular Post Share Posted March 21, 2014 Got some spare cash now so decided its time to get this thing finished. Last week i picked up a set of HSV VE discs and calipers. These are a factory fitted 4 pot caliper from AP Racing to Suit HSV VE commodores. 365mm front discs and 350mm rear. They cost me the price of a small child but due to the size of the 20" rims i seriously needed something to fill the gap. The front calipers are huge, which has lead to more problems. They hit on the spokes. Now i could just go and buy a couple of new rims but at over $1000 each from Boyde coddingtons in imearica ive decided to get the centers cut out of mine and re welded 20mm further out to clear the brakes. They are a 2 piece design, Arrow wheels tell me its not a problem. Also recently purchased is a set or airbags. Only control i have is front and rear, not left and right. This is all i want. I will be adapting a pair of VE holden rear hubs to allow fitment of the VE handbrake set up. (brake shoes inside disc) Lots of other things are progessing at the moment but will wait till i get some decent progress pictures. 11 Quote Link to comment Share on other sites More sharing options...
R100 Posted May 15, 2014 Author Share Posted May 15, 2014 This thread is so old that once the cars finished im going to re do it. It jumps all over the place with pics missing etc... Anyway heres a new pic to show updates. Things are progressing well. Found out yesterday that the 9" diff hits on the fuel tank, need to modify that to clear, will fit an intank surge tank in there at the same time. Front discs are on along with front callipers brackets however i need to get the wheel offset changed as per previous post in order to fit the mag on. Rear tubbing nearly completed. Picked up a 4 spider 3.25 ration head last week. Should give me a nice motorway cruising speed if my sums are correct. Head is so massive it only hits on everything so a bit of cutting under the rear seat is required. When its sitting on its ass the drive shaft hits the floor so the driveshaft tunnel will need to be raised along its entirety approx 5cm. 4 Quote Link to comment Share on other sites More sharing options...
