Scrubb Posted October 5, 2007 Share Posted October 5, 2007 Just read a guide on how to replace timing belt cuz I'm having problems with it not keeping timing so I'm replacing the timing/balance shaft belt and tensioners and the guide says I need to tension the belt according to the specs... Does anyone know what the belt tension specs are for a 4G32? I need both timing belt and balance shaft belt. Thanks Quote Link to comment Share on other sites More sharing options...
fuel Posted October 6, 2007 Share Posted October 6, 2007 about 1cm of deflection on the long side of the cambelt is what I set mine to, I push the tensioner out about as far as I can push it with my finger then lock it in place by doing up the bolt. Quote Link to comment Share on other sites More sharing options...
Scrubb Posted October 6, 2007 Author Share Posted October 6, 2007 Cool, thanks, Hopefully I'm getting some help tomorrow to replace it (fingers crossed) Quote Link to comment Share on other sites More sharing options...
