Hilux wheel nuts
ThePog
Ok so I have a set of EDish Ford Falcon 15" rims for the mighty lux, however thick me didn't check the nut thread for the nuts that came with them were right which they are not. The nuts are some shit imperial size and the Hilux is M12x1.5 I think. Problem is that the nuts are about 70mm long, they have a 17 ish mm diameter shank that goes through the rims then a 45 deg taper that is the clamping/centering face. I found something that may do the trick at Ripco, but true to form they were $260 for a set of 20......
It is a 92 2wd double cab by the way.
Anyone know the best place in Christchurch to source what I need?
Ta
Dylan
