Dattochriswagons Datsun collection
Discuss; viewtopic.php?f=18&t=14454
Hi, Im chris and this is my Datsun 1200 2dr wagon. Ive owned it for 1 yr now and ive dummy mounted a CA18 with plans to drop in a Turbo one once purchased. Fabricated a new tunnel, A custom X-member also sump notch. In the process of taking every panel back to bare metal and fixing rust and will end in full respray in orginal burnt orange.Suspension will be 280Z struts and brakes with adj coilover conversion. Hilux lsd in the back running discs as well. Wheels are 13x7 Jilba racing wheels,very JDM. Water to air intercooler setup and CA18det bluebird radiator. Hope to have it done be Feb 08 for the Datsun club meet at Southern Festival of speed.
  • 1 year later...
Been a long time , But here is a update, A big one.
Galant window wiper motor
Brand new door handles
Reconditioned steering
The real Datsun club membership
The wagon on its last day together with my 260C coupe, Since moved in with inlaws
Moving it across town with my ol 2dr /2 seater DX
My Jap import bus seat covers
My 180B booster with Mazda Familia M/C
My Rear quarter donor wagon
The rear quarter
My new CA18DET and box
My ARC plumbback bov
My new fuel system
My RB20 afm
My Practically new coupe Dash!!!
My sweet tool kit
My 13x7 Jilba racing wheels back from being repaired, Just a polish up now
Nardi steering wheel
engine bay bare metald efore epoxy primer
3 gauges and head unit in glove box
Just before transplant
after surgery
The hilux lsd diff in place
The 2 sets of holes, One for mazda pattern for my mags, the other datsun pattern for down the track?
  • 2 years later...
I wont bore you with the many garages ive moved my wagon to and from. But ive recently brought my own house and in turn a sweet garage.
Ill put some pics up of the wagon in its current state.
The CA18DET and all the adj suspension has been in and running and removed for paint. Im currently panel beating and getting it ready for paint.
Still got the KH330 260C coupe. Brought a 69 521 Ute also which is my daily when its not giving me grief. Mrs has got a 78 Datsun Cherry with 14x6 Hoshinos and front lip spoiler. Got a new engine for that too whcih is getting bike carbs on it.
Enjoy
Here is what ive been up to this week.
Brought a 720 with Z16 and column change with disc brakes
Removed the 521 cab and the 720 cab and about to mount the 521 cab on the 720 chassis.
Should keep me busy this week but everything looks to be lining up nicely
After a wee while aligning the cab on the chassis. Ive got it mounted.
All the mounts were 10mm to the inside of the existing holes so i re drilled them and put some big washers on. Looking mint. NOw gotta mount the booster. clutch cylinder and radiator. then its wiring time
Ok . Soo end of year festivites have consumed my evenings and the hangovers have consumed my days. But got into it this arva and got a 620 booster m/c setup bolted in place on the 521 and got the 720 radiator mounted in the 521 and plumbed up.
Gotta sort out remainder of column shift rods and brakes lines plumbed up to 620 m/c and my good friend Brendan is sorting out my wiring this week.
Maybe a skid for Xmas?
Righto!
Big thanks to John!!!
He figured out the column shift.
A bit of mucking around and got it all bolted up!!
Also over the last few nights with alot of help from Brendan ive got the brakes bleed,all the vacuam lines sorted. Wiring all tidied up, Discovered that my 1200 speedo cable and accelerator cables have connected up the to the Z and 521 componetry. Cut the last of the inner guard out of the way to clear the suspension arms.
Havent got much more to sort out really
Bleed the clutch.
Mount the deck
Wire up the rear taillights again and take it for a road test!!
Pics after deck is mounted tomorrow!!!!
Took the 521 for its first drive with new chassis under it.
Awesome power for a 1600.
Still having trouble with column shift. Cant find reverse and the gear shifts are really tight.
Hopefully sort it out tomorrow.
Just a couple wires to connect for the tail lights and it should be cool
Brendan gonna tune it up tomorrow and all going well ill be driving it out to Rangiora for the hotrod show weekend!
Here are the pics.
Ill sort out some new steels and tires at some point.
Gonna paint the new steels army olive drab with a nice sized whitewall.
Cheers guys.
Didnt make it to goon for the hot rod show. Had some last minute faults. All sorted now and looking good.
Painted the cam cover and the ufo today and then my mate Mark pinstriped her up!
Looking good now!!
Not bad for Marks first time on a car aye
also Dressed up the engine a bit
  • 2 months later...
Righto. Some motorvation kicked in over the last week or so.
Since the last update.
a 4 spd floor shift gear box went in.
510 Front Spook
Bumper Mounted
Nardi Steering wheel with homemade boss kit
Foam Hoodlining
Im trying to get it comfortable for winter at moment
So retro fit a heater. Fit sound deadning in and carpet. Seal all hole in firewall and seal windscreen
Also shorter bump stops to go in
And if anyone can help im after a 4.1 or 3.9 H190 Diff head to drop my revs at 100km . Cheers
  • 3 months later...
Actual Work on my wagon!
Brought a shit ton of panel supplies
Also had GC's the likes of Joe come round and sand up a storm on me wagon
I finished welding my last door skin
This coming saturday ive got 1/2 doz mates coming over for sanding mish then primer!
Block it back over the week after and blow some colour on the old girl!!!!!
So freakin motorvated for my wagon right now.
Cleared my garage out to get in the centre which makes things easier to work on
Righto. Saturday was good. Got heaps of sanding done. half the panels gapped. A sill section welded in
After next session its primer time
Big thanks to Josh,Mush,Joe,Andy,Dan,Brendan
Here some pics
Getting really excited about the wagons progress!
Door skins replaced on both doors
Here is primer pics!
Done the engine bay /Interior/ Underside of bonnet/Door jambs/Inside of tailgate
Stoked. A little more sanding on the body then i can primer that then its just the two doors which have a bif of sanding to do.
Hopefully prime the body next weekend then flick some colour in the jambs/inside.engine bay :D
  • 2 months later...
Update!
Me,nick,josh & don fitted up my CA18DET into my wagon this afternoon whilst a little drunk and dressed as pirates!
It went in really well!
Looks amazing and the engine bay doesnt look that bad either!
So stoked to finally have it in the painted engine bay
Ive also since sold my 260C coupe & 521 ute to other Datsun folk so i can focus more on my wagon.
It appears to be working.
Still got my Cub50 scooter and Lloyd 600 Bobber
Updates. Still getting body ready for paint. Josh has been a massive help with this. Its primed for the last time and now getting blocked back. Also scored some mint doors to replace my bog filled ones. engine is not far from starting once intercooler and intake are ready to be picked up. Its all going good. Gonna push real hard for oldschool nats roady with a little help from my friends
Had a few hours on each day of the weekend. Tidyed up a few bits and bobs. Got the handbrake lever mounted further back. Got exhaust tunnel welded in. Gearbox mounting plates welded in. Tis all looking good. Also made a panel for my 3 gauges in the glovebox. All and all its coming together nicely
