Mike-e Posted April 25, 2007 Share Posted April 25, 2007 Bought another car this morning picked up for $2g, henious paint job, grill is in the boot, no motor or box. has: lexan windows, VR4 ventilated rotors, mr2 turbo twin pot calipers, mr2 struts, molested falcon front springs, glass bonnet, wilwood brake bias adjuster, mitsi canter master cylinder, locked ae86 arse end, nice exhaust. all i can remember atm. oh, homo'd cage, 2 seats and yummy dash, expired belts. has mounts for a K series in it. plan is to get a k series to get it mobile, then cut and weld in 4ag as already have decent motor/box for it. mean. oh and guards have been pumped abit. is in serious need of chrome trims and paint/mattyb. Discussion Thread: //oldschool.co.nz/index.php?/topic/21423-mike-es-racin-rolla/?hl=mike 1 Quote Link to comment Share on other sites More sharing options...
Mike-e Posted April 26, 2007 Author Share Posted April 26, 2007 got it home on what was the most dodgiest fucken trailer mish i've done in a while big fucken chur to spence suddenly all the bullshit was worth it again Quote Link to comment Share on other sites More sharing options...
Mike-e Posted April 26, 2007 Author Share Posted April 26, 2007 trying camber shot stz Quote Link to comment Share on other sites More sharing options...
Mike-e Posted May 1, 2007 Author Share Posted May 1, 2007 doesnt drop much when you jack it up trick way clever cunt has set up some rose jointed links to keep diff nose angle correct photo op 3K in hole, some assembly required whitetail spider deadtail spider Quote Link to comment Share on other sites More sharing options...
Mike-e Posted May 2, 2007 Author Share Posted May 2, 2007 went and picked up new shortblock for it last night std 4ag blacktop done 80 mint. started to pull this motor apart for good head and conrods/pistons .....but its fucked does #4 sound noisy to you? bores 1, 2, 3 and 4, all scored to fuck, all pistons skirts to far gone to save atleast I still have this mint block and crank, need pistons/rods. gay. Quote Link to comment Share on other sites More sharing options...
Mike-e Posted August 14, 2007 Author Share Posted August 14, 2007 plans changed somewhat/heaps random messy garage pic. has been tidied since. photo op with motor sitting on jack to check viability of positions Dummy block/bellhousing/sump/box with no internals to sus mounts etc interior which is going to get dash re chopped to fit in parts for this namely one of these spares because something will break mounts, still need a little more molestation + dummy engine/head big ups to spence for toda fly Quote Link to comment Share on other sites More sharing options...
Mike-e Posted August 14, 2007 Author Share Posted August 14, 2007 more flywheel pics. aws. 4130 Chromoly steel, 3.7 kgs Quote Link to comment Share on other sites More sharing options...
Mike-e Posted August 15, 2007 Author Share Posted August 15, 2007 And the cams im using. No more annoying VVT. intake is 274 duration with 9.10mm lift and exhaust is 290 duration with 8.89mm lift. decent but am worried will be too mild for the power im after will prob end up going for more of a 298 intake and 304 ex with more like 10.5mm lift Quote Link to comment Share on other sites More sharing options...
Mike-e Posted September 7, 2007 Author Share Posted September 7, 2007 mean, got wideband, some brand new bosch coils with brackets and my ignition expander IEX ftw, if i ever get a 3tgte im so running octa coils new mega grunty (grunt = compulsory) boschys mcbang say hello to my little friend Tasty wideband. going to get a second though Quote Link to comment Share on other sites More sharing options...
Mike-e Posted October 23, 2007 Author Share Posted October 23, 2007 mean more things dual vvt-i head single vvt-i head sweet sweet crank dooot poorts sump at home inner workings of a VVT-i pulley Eagles, Beams and smallport rods Arias beams and smallport pistons fine example of a non interferance motor Quote Link to comment Share on other sites More sharing options...
Mike-e Posted October 25, 2007 Author Share Posted October 25, 2007 gtir quads and mani I may or may not chop up and use for intake manifold inside gtir plenum also stock caldina manifold i'll probably just chop up and stick a airbox on, fuck toyota pwns me more d0000rt Quote Link to comment Share on other sites More sharing options...
Mike-e Posted October 25, 2007 Author Share Posted October 25, 2007 /yeah so the gist of it is: beams 3s+forged pistons/rods @ 10:1 comp ratio + GT35 w/ fridge on front and motec telling everything what to do. still needing a gearbox and need to change my diff to something more adequate, prob gay hilux one. am after 400-500hp want to use it for tarmac rally occasionally gravel and a os trackday or two. got heaps left to do/yuh i know. Quote Link to comment Share on other sites More sharing options...
Mike-e Posted December 21, 2007 Author Share Posted December 21, 2007 very slowly Quote Link to comment Share on other sites More sharing options...
