Guest head_tech Posted January 5, 2007 Share Posted January 5, 2007 Maybe the rocker shaft is worn? you wont ever get them right if it is...try sliding a rocker across out of the way (you'll need to back the rocker adjustment right off) and check the underside of the shaft for wear you should be able to feel any wear, from memory those mitis engines wear rocker shafts good luck Quote Link to comment Share on other sites More sharing options...
