PintoPusher Posted December 30, 2006 Share Posted December 30, 2006 just bought an xf falcon, has reconditioned alternator, battery light on dash goes out once engine has been started though battery is not charging anyone got any ideas, i havent even started having a look yet... could be something as easy as fuses... dont know... anyone know of any common charging system fault with this vehicle... has analog dash with digital fuel and temp gauges etc etc Quote Link to comment Share on other sites More sharing options...
rxsumo Posted December 30, 2006 Share Posted December 30, 2006 I assume you have checked the battery doesnt have a dead cell, and that you arent seeing the voltage incresae at the battery when the alternator kicks in? The dash has a second "layer" of digital gauges, one of these is a volt meter, and this should be flashing if the alternator is not working as well. Quote Link to comment Share on other sites More sharing options...
PintoPusher Posted December 31, 2006 Author Share Posted December 31, 2006 so does this mean those digital gauges are part of the charging circuit??? because they arent working at the moment and im beginnning to wonder if thats the reason the battery isnt charging?? have tried 2 different batteries... same result Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted December 31, 2006 Share Posted December 31, 2006 Get a multi meter or volt meter and put it across the battery. Check the voltage, I'd expect it to read between 13v-14v(You may need to rev the engine). This shows that alternator is working properly and this will confirm that the dash light is telling the truth and your battery is probably poked. Quote Link to comment Share on other sites More sharing options...
PintoPusher Posted January 1, 2007 Author Share Posted January 1, 2007 have jump started the coon, disconnected the battery... it still runs without the battery connected so i assume the charging system is fine, yes the battery is not holding charge... however the digital dash, fuel gauge/temp gauge and voltmeter are not working... is this related to the battery or is it cause by a fault somewhere in the system??? Quote Link to comment Share on other sites More sharing options...
PintoPusher Posted January 1, 2007 Author Share Posted January 1, 2007 problem solved... im such a fucktard... should check all the fuses before i ask questions aye Quote Link to comment Share on other sites More sharing options...
PintoPusher Posted January 1, 2007 Author Share Posted January 1, 2007 update. okay, got the dash going, replaced the battery, vehicle runs with battery terminals disconnected, connect battery and go for a drive, voltmeter on dash show voltage dropping.... anyone got an answer for this??? faulty alternator?? only producing a small charge at low revs and increasing revs uses more power which is why the voltage is dropping??? correct??? Quote Link to comment Share on other sites More sharing options...
PintoPusher Posted January 2, 2007 Author Share Posted January 2, 2007 put fully charged battery in this morning, started, voltage on dash dropped to 2bars, turned off, voltage went back upto 4bars... i really should go buy myself a multimeter i think Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 2, 2007 Share Posted January 2, 2007 try regulator if the voltage is dropping with increased revs. had same prob on van and crown. I'd be incloned to run an ammeter & voltmeter checkto confirm if it were me though. also battery can be fucked over with this prob so make sure that's not causing you grief too. recon alterator should have had that shit checked also, unless they just maori'd it up with a set of brushes etc Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 2, 2007 Share Posted January 2, 2007 I want a falcon/fairmont that runs on lpg, hookups anyone? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 2, 2007 Share Posted January 2, 2007 buy one that's already set up I want an xd Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 2, 2007 Share Posted January 2, 2007 yeah im too lazy to set it up myself Quote Link to comment Share on other sites More sharing options...
PintoPusher Posted January 3, 2007 Author Share Posted January 3, 2007 thanks for all the advice fullas... seems the coons not my only problem at the moment... fuckn missus having a bleet coz i spent more time on the car than with her these days... lmfao!!!! at less the car doesnt whinge!!!! Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 3, 2007 Share Posted January 3, 2007 ditch that stz and go take the XF for a thrash Quote Link to comment Share on other sites More sharing options...
PintoPusher Posted January 3, 2007 Author Share Posted January 3, 2007 fwark yeah mate i wud... if only the battery was charging!!!! going to get a new regulator tomorrow Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted January 4, 2007 Share Posted January 4, 2007 I want an xd I dunno if you've seen this one ...it's on traders http://www.trademe.co.nz/Trade-Me-Motor ... 048685.htm Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 4, 2007 Share Posted January 4, 2007 zomg rofl. sw that a while back but yuh. If i were looking for another big car, then a mint 6yl XD would perhaps feature, if it were cheap as chips. many fond memories from my parents one back in the day etc. Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted January 4, 2007 Share Posted January 4, 2007 zomg rofl. sw that a while backbut yuh. If i were looking for another big car, then a mint 6yl XD would perhaps feature, if it were cheap as chips. many fond memories from my parents one back in the day etc. Just on the quiet RT may know of a Dedicated LPG XF going for cheap soon... it's in Chch Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 4, 2007 Share Posted January 4, 2007 oh yuh. me = not gon' be going near anyting such as that for a fair while yet. am content in the crown for now. Pete (retep130) uttered words of being keen on such a thing a few days ago Quote Link to comment Share on other sites More sharing options...
PintoPusher Posted January 8, 2007 Author Share Posted January 8, 2007 thats one phat xf wagg'n cant exactly call it a shagg'n wagg'n anymore though... i mean if you were a dwarf then sure... it wud work, but... i dont think a dwarf could reach the peddles in one of those beasts, kinda renders it completey usless but none the less it still looks phat, what wud be mean though is an xf wagg'n convertable with a spa and mini bar in the back Quote Link to comment Share on other sites More sharing options...
