Guest 13BPPTURBO Posted November 1, 2006 Share Posted November 1, 2006 Ok here are some measurements of some toyota diffs that iv got. #1# 4x4 lsd diff* AXLE LENGTH = 598mm AXLE DI =33.5mm HOUSING LENGTH=1M230mm #2# early non lsd ute* AXLE LENGTH = 613mm AXLE DI = 32.5mm HOUSING LENGTH =1M245mm #3# non lsd van* AXLE LENGTH = 613mm AXLE DI =34.5mm HOUSING LENGTH= 1M258mm #4# lsd ute axles* AXLE LENGTH = 610mm AXLE DI =34.1mm i hope thes specs will help any one wanting to convert to the stronger toyota diff for my datsun ute i am using a 4x4 housing (#1#) with my lsd axles (#4#). all the splines on the heads and axles are the same. im using my 4.8 locker. Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 2, 2006 Share Posted November 2, 2006 I have a hiace diff with differant axles. Are all of yours same count on axles. Where are you measuring from? mounting face to mounting face or what? Cheers. Quote Link to comment Share on other sites More sharing options...
Guest 13BPPTURBO Posted November 2, 2006 Share Posted November 2, 2006 I have a hiace diff with differant axles. Are all of yours same count on axles.Where are you measuring from? mounting face to mounting face or what? Cheers. housings wer measured with out axles. axles wer measured from the flat surface wer the 4 bolts are to end of axle. all axles have same amount of teeth as do the heads meaning i can use diferent head/axle/housing combos . ur diff/axles may have come from a toyota dyna van they look the same but i think thes are a bit diferent from the hiace van diffs Quote Link to comment Share on other sites More sharing options...
