Raizer Posted July 31, 2006 Share Posted July 31, 2006 a mate of mine has just replaced the head gasket on a Corona with a 3SFE in it. The problem is we cant figure out how to get the cams set up again (Twin cam, 1 cambelt pully), any of you know how/have a workshop manuel you could scan? I think there the same setup as a 3SGE Quote Link to comment Share on other sites More sharing options...
510WGN Posted August 1, 2006 Share Posted August 1, 2006 Line up the dots on the two gears in middle of camshafts. The spoke in cam gear with small hole should be at the top and be able to see through to groove in top of seal carrier. Quote Link to comment Share on other sites More sharing options...
