Guest evotoy Posted November 21, 2005 Share Posted November 21, 2005 Anyone here installed Tension strut system in a Mk2/Mk1 Escort? I have installed adjustable rosejointed lower TCAs and need to make the front end more accurate.... the rosejoints seem to allow too much movement/roll on the TCA... Tension/compression struts are apparently the answer... i would prefer Tension strut with a rollbar.... Gatrac in the UK do the kit for around NZ$1000..... whereas the Compression strut is only $350.... (but no provision for an anti-rollbar).... Any pics or links would be appreciated. PS if I go this way then I will have some standard eurathane bushed TCA's and a mint set of sway bar mounts which have been fabricated for anti-dive and double width bushes.... Cheers Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 22, 2005 Share Posted November 22, 2005 ive just had a look at the escort and cortina restoration book and it says that compression struts were used instead of anti roll bars, theres a kit on the burtonpower website part number RD193 for 123pounds. could you get better tca's? Quote Link to comment Share on other sites More sharing options...
Guest evotoy Posted November 22, 2005 Share Posted November 22, 2005 already got the good TCA's.... the ones from burton... rose-jointed and in-situ adjustable.... Compression struts were used early on then dumped.... and yes they dont use a sway bar... but as for pushing the car hard I will need a sway bar to help stem oversteer.... Anyone out there got a Gartrac parts book in PDF? Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 23, 2005 Share Posted November 23, 2005 i want the gartrac pdf too if anyone has it Quote Link to comment Share on other sites More sharing options...
