WildPlumDx Posted July 30, 2005 Share Posted July 30, 2005 my mate done my timing today but not sure its right coz first he didnt even use the bright links to set it up! but hes sure its all good he reakons you dont need too use them but i'm not so sure! what do you guys think coz i'm unkeen to pull it apart again if hes done it wrong! whats the worse you can do if your engines out of time besides bend valves? Quote Link to comment Share on other sites More sharing options...
Guest ww Posted July 30, 2005 Share Posted July 30, 2005 whind the engine over buy hand and see if it locks up if it get tight and cant be moved the timing is out, if you can do a couple of revs the valves arent going to hit he pistons, so you can start it and see if he is a tooth or 2 out. Quote Link to comment Share on other sites More sharing options...
Defcon Posted July 31, 2005 Share Posted July 31, 2005 Yeah as ww said, crank it by hand a few times to see if the valves hit the pistons, if not then you sweet. I never used the bright links when i did my timing, and it was spot on. Def' Quote Link to comment Share on other sites More sharing options...
510WGN Posted July 31, 2005 Share Posted July 31, 2005 By saying bright links I guess you are talking about timing an engine that has a timing chain?? If so, it doesn't really matter where you have the links as long as you KNOW the cam and crank gears are properly aligned. Also it'd take HEAPS of revolutions to line up the links with the timing marks on the gears too, unless you wanted to remove the chain and start again. You can turn the engine over by hand to make sure as said above, but if only a few teeth out, the piston could still miss the valves but would run like shit!! Quote Link to comment Share on other sites More sharing options...
WildPlumDx Posted August 2, 2005 Author Share Posted August 2, 2005 yeah i got it sussed i reakon pulled it back apart so dont reakon my mate did it right done it all myself now gonna hope for the best lol you'll hear aboiut it if i screw my engine! she'll be sweet as i'm sure cheers for the info tho! Quote Link to comment Share on other sites More sharing options...
