Defcon Posted June 15, 2005 Share Posted June 15, 2005 Heres the coupe in progress, Chassis:standard, Suspension: Front; King Springs with Tochi sports shocks, Nolathane Shock and sway bar bushes, Rear; king springs with adjustable rancho shocks, Brakes: Front: Larger ,vented Audi Rotors and Vb commy Calipers Rear:Standard with everything reco'd Engine: G200 2ltr OHC with reground cam, shaved head, Twin 40mm Idf webers and extractors, Driveline: Standard. Wheels: Still comming Engine needs to be put in, should be soon in the comming Uni hollidays i hope, and the same with the wheels. Quote Link to comment Share on other sites More sharing options...
Defcon Posted July 2, 2005 Author Share Posted July 2, 2005 Update, 15" ssr wheels, Engine to go in ,starting monday. Gauges installed, Quote Link to comment Share on other sites More sharing options...
Defcon Posted July 21, 2005 Author Share Posted July 21, 2005 Engine and box finally in, but with a whole host of now apparant porblems to fix, Oil leaking out of the bock where the pressure sender snaped off- clutch no engaging- so the box has to come out again, the box also needs a new rear out put seal. Pic's as goes so far. And yes, we did actually put the 2ltr in at night in the rain, that is devotion! both Zep and I were rolling around in puddles of water with bugger all light trying to align a drive shaft. Quote Link to comment Share on other sites More sharing options...
Defcon Posted April 11, 2006 Author Share Posted April 11, 2006 UPDATE. Installed a One inch master cyclinder, solved all my braking issues. Also installed a pertronics ignition, makes a real differance, idles much smoother and its far more responsive. Have also put on a whiteline sway bar and some better front pads. Really happy with the way she drives at the moment. Matt Quote Link to comment Share on other sites More sharing options...
Defcon Posted May 30, 2006 Author Share Posted May 30, 2006 More Pictures; Looks shocking, Really need to do something about the engine bay o_0 Quote Link to comment Share on other sites More sharing options...
Defcon Posted November 2, 2006 Author Share Posted November 2, 2006 Some better pictures of the rat gem. Scored a paint job from the olds for my 21st so hoefully it will be painted in time for new-years, good bye rat look Quote Link to comment Share on other sites More sharing options...
