Defcon's '78 gemini coupe
Defcon
Heres the coupe in progress,
Chassis:standard,
Suspension: Front; King Springs with Tochi sports shocks, Nolathane Shock and sway bar bushes, Rear; king springs with adjustable rancho shocks,
Brakes: Front: Larger ,vented Audi Rotors and Vb commy Calipers
Rear:Standard with everything reco'd
Engine: G200 2ltr OHC with reground cam, shaved head, Twin 40mm Idf webers and extractors,
Driveline: Standard.
Wheels: Still comming
Engine needs to be put in, should be soon in the comming Uni hollidays i hope, and the same with the wheels.
Engine and box finally in, but with a whole host of now apparant porblems to fix, Oil leaking out of the bock where the pressure sender snaped off- clutch no engaging- so the box has to come out again, the box also needs a new rear out put seal. Pic's as goes so far. And yes, we did actually put the 2ltr in at night in the rain, that is devotion! both Zep and I were rolling around in puddles of water with bugger all light trying to align a drive shaft.
  • 8 months later...
UPDATE.
Installed a One inch master cyclinder, solved all my braking issues.
Also installed a pertronics ignition, makes a real differance, idles much smoother and its far more responsive.
Have also put on a whiteline sway bar and some better front pads.
Really happy with the way she drives at the moment.
Matt
  • 5 months later...
