Guest dreadedretard Posted April 3, 2005 Share Posted April 3, 2005 Just before i noticed my bonnet looked very odd. standing up higher than usual. Me being a good car owner had a look and thought, ill pop the bonnet and see whats up with the clips and blah blah. The problem was.. it wont open. I removed the grill to help get into it didnt help much. So i am absolutely stuck with ideas. I poked at it with screw drivers and played with the springs and the bonnet latch. So... any ideas? people willing to give a hand? Cheers. Quote Link to comment Share on other sites More sharing options...
atropine Posted April 3, 2005 Share Posted April 3, 2005 ring aa roadside rescue Quote Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted April 3, 2005 Share Posted April 3, 2005 but im not on the roadside. lol yea i dunno Quote Link to comment Share on other sites More sharing options...
atropine Posted April 3, 2005 Share Posted April 3, 2005 then take it down the road and pretend something else is wrong Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted April 3, 2005 Share Posted April 3, 2005 sorry to here that,i would come over and help but i might be a while as id be coming down from hamilton.hahaha seriously tho ive owned several minis and never had that problem b4 Quote Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted April 3, 2005 Share Posted April 3, 2005 Its so screwed ay... i just really dont get it. Just start driving now:P be here tomorro night Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted April 3, 2005 Share Posted April 3, 2005 is the centre pin on the front of the bonnet bent maybe? you havent shut the bonnet with a screwdriver or spanner or some thing have you? Quote Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted April 3, 2005 Share Posted April 3, 2005 I thought it was the spring or the latch. But i fiddled with the spring to see if it was caught on the latch or anything but couldnt feel anything ay.. its really annoying me and i dont get it ay.. once i get it open screw latches im either taking the bonnet off completely or converting to a quick release one with bonnet 4 bonnet pins. and no i didnt close it with a screw driver or spanner. cheers. Quote Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted April 4, 2005 Share Posted April 4, 2005 I just opened it.. woohoo it was the spring. It was caught on the latch. which is weird:| but oh well. But im still fucked off cause' and of my grill. Its not lining up with the bonnet at all ay.. The bonnet sits way too high so the mistache bit i think is sitting about 10mm-20mm up so it doesnt meet up with the other chrome surround on the main grill. Ive adjusted the centre pin but it didnt lower it. Only make it harder to shut. come on guys! i need help! Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted April 4, 2005 Share Posted April 4, 2005 rip the shit out and bonnet pin it Quote Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted April 4, 2005 Share Posted April 4, 2005 Yea ive been thinking of that. Should i go 4 or 2? And do you know what they cost and where to get them? Quote Link to comment Share on other sites More sharing options...
atropine Posted April 4, 2005 Share Posted April 4, 2005 i got a pair from repco.. around 30bucks i think Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted April 4, 2005 Share Posted April 4, 2005 you could go 2 at the back,rubber straps at the front or leather i spose Quote Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted April 4, 2005 Share Posted April 4, 2005 I might just get a pair for the front. and just leave the back on hinges and when i get more money and a bit of engine mods and looking betta ill get the other pair. Quote Link to comment Share on other sites More sharing options...
Guest rip Posted April 4, 2005 Share Posted April 4, 2005 Hi The center pin on your bonnet was possabily working loose and came out of adjustment which would answer why it suddenly sat higher. If you look at it you should see how to adjust it back and when you get it sitting right lock the lock nut up. I can't check mine to explain it better as my shell has just gone to be painted. But from memory the pointy bit at the end has got a screw slot in it adjust that up or down against the spring and I am sure theres a lock nut to stop it comming out of adjustment once set. Good Luck it should be easy Roy Quote Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted April 4, 2005 Share Posted April 4, 2005 Hey thanks for that. But ive put the spring real small as small as it can go and it wont go any lower. It stays at the same height. It looks awful. i know it sounds picky but to me the grill does not look right at all. It really needs to line up with the other surrounds. cheers. Quote Link to comment Share on other sites More sharing options...
Guest rip Posted April 5, 2005 Share Posted April 5, 2005 hmm OK you say "The bonnet sits way too high so the mistache bit i think is sitting about 10mm-20mm up so it doesnt meet up with the other chrome surround on the main grill" Did the fit look right when you first got it. What year is your mini if it had a "mo" grill from new it should be a MK1 and have external door hinges. I ask this cause the "mo" grills are sort after and are some times fitted to later marks. I read it some where in a Mini World mag I think there are mods to do to make it right. One was the lip on the bonnet had to be cut off can't remember if or what else. So have I look at some other round nose mini's to see if you can spot the differance. Cheers Roy Quote Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted April 5, 2005 Share Posted April 5, 2005 Im not really sure about what sort of grill it is. I dont think its a mustache one now. its just a chrome strip which is squarish along the bonnet. I fixed it by just moving the whole grill up and re-screwing it. Its just temporary till i either get a mesh grill with the original chrome surround or a full new grill from the UK or summing. Cheers. Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted April 6, 2005 Share Posted April 6, 2005 if the mini youre talking about is the one in your avatar,i noticed it has internal hinges which tells me"late model",which means the grill may have been retrofitted,you my be able to tell by the front lip on the bonnet should have been ground back cos they have different bonnets(just the lip i mean) Quote Link to comment Share on other sites More sharing options...
Guest dreadedretard Posted April 6, 2005 Share Posted April 6, 2005 Yea it is that mini. Its a 1975 AUstin and well.. im really not sure. Im almost ready to give up ay.. ive just moved the grill up for the time being just to make it looks alright. I dont tihnk its the right bonnet. It doesnt sit right no matter how much i try adjust things. Thought it may have been re-done and put on same with the grill. Its had a new paint job before i got it. Its a bit rough but its ok and when i first took off the grill i notced there were fresh holes where the grill was screwed into. And i couldnt see any original holes. Which is strange... Quote Link to comment Share on other sites More sharing options...
