Guest 66 cortiner Posted March 22, 2005 Share Posted March 22, 2005 hay guyz i have decided that i am going to chuck out the auto and slamm in the manual gearbox im making it floor change is there tricky parts i should no b4 i start my mish. Quote Link to comment Share on other sites More sharing options...
mkcortina Posted March 22, 2005 Share Posted March 22, 2005 the hardest thing will be finding a gearbox 2000E this is the best gearbox for a 1500cc have a look at http://www.burtonpower.com then go to tech support and select "2000E Bullet" other things youll need to do 1) is get a pedal box if you cant find 1 i have my old 1 spare 2) you will ahve to get a fly wheel they use a 4 bolt "escort uses 6 bolt" 3) it uses a hydraulic clutch so you will need to connect all that. 4) drive shaft i think it will be different but easy to get 1 built. 5) getting a clutch is a pain you cant just go buy a kit no one has 1 they can only rebuild std 1's but you can change it to an escort clutch with some mod's. there is alot of things you have to get but it will be worth it hope that helps Quote Link to comment Share on other sites More sharing options...
Guest 66 cortiner Posted March 22, 2005 Share Posted March 22, 2005 the hardest thing will be finding a gearbox2000E this is the best gearbox for a 1500cc have a look at http://www.burtonpower.com then go to tech support and select "2000E Bullet" other things youll need to do 1) is get a pedal box if you cant find 1 i have my old 1 spare 2) you will ahve to get a fly wheel they use a 4 bolt "escort uses 6 bolt" 3) it uses a hydraulic clutch so you will need to connect all that. 4) drive shaft i think it will be different but easy to get 1 built. 5) getting a clutch is a pain you cant just go buy a kit no one has 1 they can only rebuild std 1's but you can change it to an escort clutch with some mod's. there is alot of things you have to get but it will be worth it hope that helps Quote Link to comment Share on other sites More sharing options...
Guest 66 cortiner Posted March 22, 2005 Share Posted March 22, 2005 hey man sorry bout that i mucked up a bit. I,v got a gear box but i need all the other shit to go with that.is ur peddle box in good condition.cheerz 4 all that info man that was wicked.i dont no wat the gear box is 2000E but it is a colimn change but i want to put it into a floor change is there much cost for doing that. Quote Link to comment Share on other sites More sharing options...
mkcortina Posted March 22, 2005 Share Posted March 22, 2005 i dont know if you can change it you would have to go talk to a gearbox shop. if you can find a 2000E gearbox it would be best as the gear stick is at the end of the gearbox as the others will have a long truck like gear stick Quote Link to comment Share on other sites More sharing options...
