Posts posted by beachlander
/I'm assuming the parts are removed?
I'll ask my boss tomorrow and see if I can do it for you
Will chuck some money through tonight
I will be trying to be there for at least one day
I like this very much
Still havent seen a picture of underneath it.
Finally got some tires on the equips, and tried them on.
As you can see, there is a slight issue. Will be going to 165/65 from 185/55 for more clearance, and a slight guard roll.
Will maybe go to a 165 on the front as well, 175/60 in this photo.
Also had some factory side skirts show up as well as a rear sump set up. Just need JZA70 engine mounts and then the engine can go in once i pick it up.
- 6
Project thread: //oldschool.co.nz/index.php?/topic/46383-andy-gals-gx60-mark-ii-wagon/
Sell to me plz k thnks bye
13s max. And preferably not rotas
15mm adaptors are always a bit of a drama. either the nut is too shallow, so it doesnt comply with the minimum thread engagement rule of 'same as thread diameter', or there isnt enough material left under the nut taper and they warp/are not strong enough. 20mm ones always seems to work out easier.
you can trim the stud if it sticks out past the face of the adaptor. you wouldnt be able to machine the rim.
i hate adaptors. theres so many china ones around with shitty nuts that the taper doesnt match, or the taper is machined not parallel with the thread.....
So I've finally got round to doing this. Ended up with znoelli 15mm spacers. Have cut the stustuds back flush with the nuts, which was only about 5mm. When the wheel is on, the nut is only slightly touching the wheel. If I took another 2mm off the nut and stud, would this be a problem? The nit is 16mm thick, and there is 6 mm from the face of the nut to the face of the adaptor.
Fully thought this was going to be progress. Got all excited for a second
Rainy meets tend to bring more people. Don't think they will all fit downstairs
The rubber mount? Should be able to buy one new from the mount shop etc
I quite enjoyed watching this hoon.
Sounds like it won't like my car then
I've always been told to have the deflection the same thickness as the belt. Is what I have done and never had slippage/problems
Car stacking time
I might be keen on this depending if my cars working
I just want burgers
Don't keep your foot up oover ripple strips/don't do ridiculous launches and you'll be fine
Got a helmet. Was here in 10 days
You amaze me
NZFMR 2015 Photo Coverage Thread
in General Car Chat
Oh my those are amazing
