rwdevo
New Members
rwdevo's Achievements
Newbie
Newbie (1/5)
0
  1. hey man what did you do to your accelerator cable to get it to reach the TB
  2. to caboonatlarge. ive got some starion struts and wanna put coil overs on. were did you find the coil over sleeves? as all they have on trade me is 51mm tubes and the starions are 54mm so i havent been able to find any! any help on this?
  3. hey bro what are those rear shocks out of? i see it say vs mirage but what year etc? did they bolt staright in?
  4. sweet as bro. what size clutch have you used? 215mm or 225mm? and was it just a standard sigma one or have you got a heavy duty clutch disc? oh and what have you done to your accelerator cable? have you modified the original or got one of a diffrent car? as mine dont reach to my throttle body
  5. ok sweet as bro. who did your water setup from round the back under the inlet? its pretty good way of doing it im thinking doing it like that now just gotta make it up i geuss!
  6. hey guys ive got a link also and need to do the wiring. were do i start and what do i do? i no which plugs go to motor etc just dont no what else to do with other connections
  7. Hey bro im doing the same conversion with a 7 bolt evo. ill start a project forum of my build when i get some time. i need some major help with the wiring? im also running an after market link computer. wea do i start and what do i need? i have the engine harness, i no which plug belongs each plug to on the motor. just dont understand how i do it. any help would be awesome. i have an evo flywheel on it but i have sigma ring gear on it so the starter is in original pos. one mistake i made was shaving the steps off the flywheel so i could use rwd sigma clutch and pp plate and i cannot find a clutch strong enough now. i didnt the the flywheel with the steps it had on it was going to fit but i see you have made it
