Posts posted by Evan
I've watched a few of those vids of that CF 240z. It's a bit of a balls up how all he is doing is laying carbon over the factory panel to make the new panel, then removing the original panel to attach the new CF panel. The whole car is going to end up fractionally larger that it should be, curious to see how it affects panel gaps and things like tail light fitment. Also the nice smooth finish ends up being on the inside of the panel, which you don't see...
- 5
I've considered that, could make some additional moulds to work with what I've got and give that a go too, I just don't know if it would be runny enough to get into all the spots.
Yeah from what I've read it depends on the resin and what temp you cure it at, some are 70 C, some are 90 C some are 140 C. Don't know until you try, if it doesn't work out no harm done etc.
Has anyone here done anything with prepreg carbon fibre? I've been umming and ahhing over what to do with respect to the intake manifolds I've printed for the v12 Jag engine I have. The obvious thing to do would be lost wax casting but I'm not really interested in that. After watching those easy composites videos approx 18 months ago I've wanted to try and make something out of prepreg carbon ever since so thought I'd try and make these manifolds out of carbon.
I sprayed the print with some high build primer and sanded it back to smooth it out. So far the biggest decision has been what to make the mould out of, have decided to give silicone a go as it's supposedly temperature stable to like 220 degrees Celsius. Will put a box of some description around the mould for support and hopefully be able to out-of-autoclave bake it in the oven to cure the carbon. Plan to import one of the easy composites starter kits with the vacummn pump etc and have a play. Hope to report back with how I get on.
I stuffed up when i poured the first half of the mould and forgot to put locating dowels in to align the 2 halves, should be able to wing it though.
I should really start with a simpler shape haha...
You didn't used to work with an Aussie guy called Julian did You?
On 10/02/2018 at 11:18, AALAWS said:
I was just going to post about this too......I need my ke25 rust cut to somehow appear in the Waikato/Otorohanga if anyone's making a trip??
You get this sorted?
Bags, 1GZ and brown paint
That is all.
Yeah would do an m117
You're all wrong
OM606 or bust
Check again for rust updates. you got any photos of yours pre-paint for a comparison?
RE Lexus, those photos are taken at Neds, where it's being stored for the next couple of months while it waits for a panel beater, it's his Lexus
And the LHS shown here
There's other bits an pieces (holes) all over but that's the worst of it. I'm not sure if it has had work done in the past or whether it could be from the factory but there are a number of parts on the car that are lead filled/patched (how bad ass is that!?)
Anyway, I've been trawling Ebay.de and niemoeller.de ordering repair panels, still need to get the big ones through (left sill and boot floor). You can get quite a lot for these cars from Germany which is good. Standby for more.
Shoulda just bought UJs one.
- 27
It turned out to be a bit holy-er than I thought it was. We will start with the Good - the roof! Apart from a small dent above the right rear door it might as well be brand new!
You can semi make out in the bottom right corner of that second photo and the top of the next photo some cut marks around the upper lip of the parcel shelf. The previous owner has cut chunks out of that entire lip all the way around, which is going to be a pain to correct
The Engine bay isn't bad either, a few pin holes around where the brake master cylinder bolts up, but no rust under the battery mount.
- 8
It spent a week at Autoblast getting blasted all over with the exception of the underside of the roof, dash, and trans tunnel. before being coated in primer. I definitely recommend the service Dave and his guys at Autoblast do and the care they take not to warp anything. Came back looking like this:
Originally I was going to scrape what underseal was on it off before sending it to be blasted. However I ran out of time/CBF with it any more so sent it out as it was, giving them the instructions to hit it and if it doesn't come off with 260PSI of air/garnet attacking it, it can stay, which is why you can see some primered over underseal in the wheel arch area.
So that was roughtly June/July last year, the car sat in Archetype shed until the new year where I spent a week commuting back and forth to his house to pull it apart over the xmas break. I don't understand how some people can live in Hamilton and commute to Auckland for work - it's the worst drive in the world.
It all came apart reasonably easy except for a bit of dicking around with the heater core and a bit of lost sweat trying to get the dash pad out.
The floors got the dry ice and hammer treatment to get the sound deadening out. This revealed what I suspected when I pick up the car originally, that the front left floor pan/sill area was junk. The front left door flexed a bit when the strop was slammed in it when it was on the trailer, which suggested the area was a bit soft. you can kind of make out a bit of daylight through the passenger floorwell in the above photo.
- 8
Kia Ora
A couple of people have asked where the build thread for my car is because they want to watch, there hasn't been much building - mainly de-building up to this stage but here goes.
As part of my daily quest to be more like UJ about 6, 8 or 10 months back I was trawling trademe as I regularly do, seeing what's new.There was a fresh ad up for a Fintail Mercedes Sedan with the usual 3 shitty photos.This was right around the time I brought the v12 Jag motor discussed elsewhere, I mean one hobby is good but twos better right? This thing is also the reason progress on the V12 has stopped because I've been spending spare time swimming and getting the ball rolling on this.
Anyway the ad as mentioned had 3 shitty photos on it, one of which was of a grainy pic of a not-so-Mercedes Falcon motor that it was fitted with. As a result of the Falcon motor the guy who owned it was getting all sorts of grief about it not having a Merc motor. Bugger that I thought, I'll go have a look. Long story short the guy wanted rid of it as it was a project he and his Son who's since left home had that never got anywhere and he just wanted the shed space, he didn't care what he got for it and couldn't be bothered dealing with the whinging people on trademe.
So I bought it then and there.
This is what it looked like when I got it, forever known as the OTP mobile.
It's a 1965 Mercedes Benz 220Seb (W111 Chassis for those that care) in black, just like UJ, sort of. From what I understand 220 is the engine size (pretty obvious 2.2 litre), S is the bling model, b means its a fintail (the predecessor to this shape was also called a 220), and E, I believe, means it was a factory injected car but I'm probably wrong on that. It doesn't matter as it has the aforementioned Falcon 6 weighing the front down now. It appears to be complete, everything that is missing in the above photos is in the boot.
When it was listed it was listed the guy said it was deregistered, a quick carjam report said that it wasn't deregistered, that it had simply lapsed and was due to deregister 2 weeks after I brought it, so I quickly put it back on hold after I picked it up. Live reg = Whoop.
Props go to Sentra for tow car supply and Archetype for Storage.
- 23
On 2/26/2018 at 19:10, aT_eAse said:
Called Woodhead last week and they have a 3 month waiting list.
That's pretty normal.
I'd be cautious of anyone who doesn't have a (reasonable) waiting list, think along the lines of 'why does no one want to use/wait for their services?'
I've watched the easy composites videos myself and it looks like they will ship prepreg to your door (they're in the UK), think the stuff has about a months shelf life once thawed.
Just finished mopping up all the foam off my floor
20 hours ago, nacnud said:
Keen to hear some recommendations on places for getting chassis blasted and epoxy please team.!
Phoned around a few buy keen to hear who you guys have used before.
Thanks!
Autoblast in Glenfield
Left to rot.....
in General Car Chat
Looks like it's moving pretty fast in the photo.
