azzurro
Posts posted by azzurro
  1. Took the car out to Caffine and Classics today,
    //oldschool.co.nz/index.php?/topic/42367-caffiene-and-classics-23-febraury-smales-farm-akl-10am/?p=1349227
    on the way there i got a puncture/flat tyre, but the tyres are a bit old and pretty stuffed had slow leaks anyway so this afternoon after taking this last photo with (3 out of 4) the wards on (for now):
    i swapped back to my meshies with nice near-new Direzzas, which i repainted to an off-white aaages ago, and some better wheel bolts instead of the (bloody rubbish!) two piece conversion studs i had before
    Also took another half coil out of the front and put an extra 5mm wheel spacer on too, could maybe go another half coil, but ill wait till the 2L is in as its a bit heavier - suspension seems quite a bit firmer too.
    Pretty happy with that, hopefully the meshies will gain some depth when they dust up a bit.
    the 1608cc engine still starts and runs really nice, but it left this mess on the driveway,
    This is just from from sittling while swapping the rims over today, which is very annoying after changing all the seals not long ago, and its embarressingly smokey on over run going down hills etc as well.
    So Ive also pulled finger and built up the 2L and stuck the 5 speed gearbox onto it,
    just waiting on a couple of small bits and bobs (which may turn into a big order now im getting them from overseas...), and hopefully getting the main missing puzzle piece :
    a 5 speed tunnel section should be making its way up in the next couple of weeks  :D :D  :D
    • Like 7
  2. If it was workign sweet for 6-8 months then its not palsides fault. If it is a sudden change then its something that has suddenly changed to cause this.
    what i mean is you should find and fix the issue properly, instead of masking it with more force.
    should return to closed without a large® return spring (on the accellerator cable or whatever) there is a small coil spring on the end of the throttle shaft(s) which is more than capable of snapping the throttle closed - if this isnt working propertly theres something wrong (could be that very spring of course).
    Its probalby something dumb like a nut comeing a bit loose and letting something catch.
    You also said its flooding? non-closed butterflys will let in more air & fuel so will be running on idle/transition or main circuit rather than just too much gas? ie will 'idle' really fast.
  3. Moved the Croma to mow the lawn under it again.
    swapped the original injectors back in (with new orings and filters) and took it for a blast. Goes great guns, if a bit laggy, and no skids (did a mean one getting it off the grass tho!)
    Seems to cut the ingition or something, on high load - i think it may be fuel related (fuel pump too weak?) as the OEM higher flowing injectors have moved the cut sumptoms up the rev range a bit from the last time i took it out.
    On the way back from the last run, it blew an intercooler hose off, but lucky the walk home to get a scredriver wasnt too far!
    back on and now it wont idle and is hard starting, and i seem to have lost a park light cover, so thats that i suppose.
    Mowed its patch before putting it back, but the next time it gets driven is to get its engine pulled out.
    i <3 boost...
  4. they are pretty simple mechanically, you should be a ble to spot it, but you might need to pull it off the manifold
    could be
    - something jammed in there,
    - one of the springs or tabs on one end of the throttle shaft has shifted or come loose/catching on something?
    - butterfly come loose?
    - throttle shaft a bit bent (they run on bearings)?
  5. ACCs failure to clearly communicate something that is so obviously going to cause a lot of public hoohaa is the actual problem here.
    A simple table that showed in simple terms what they were going to do should have been in the press release, eg:
    "Car older than X = Vintage and not affected (and in fact a bit cheaper)
    Car newer than Y and 5 star (or whatever) = deemed Safe and levys reduced.
    All others see attached table, you are probably going up unless you car has a high crash rating*
    *exceptions too all the above may apply, read the fine print suckers."
  6. EURON8 came over yesterday afternoon to see if we could get the Croma moving, the only thing stopping it being the clutch.
    Jacked it up, and managed to get the turbo winding up while in gear and applying the brakes :)
    (also to try to jolt the clutch off the flywheel)
    Thus motivated and after some epic bleeding and bodging there is enough clutch to just disengage the cutch while in gear and took it for a blast.
    is actually really nice to drive and the engine will be certainly scary enough in the 125.
    The Croma were set up as a tourqy cruiser rather than a top end screamer and is pulled well.
    I think it was leaning out on boost tho, so I will clean up the original injectors and put them back in and tidy a few other things before a couple more test drives :).
    Success!
  7. clutch pedal feel is very soft and stays on the floor, but shifts the slave about 5-10mm (which is about the same as my corolla), and im pretty sure the hydralics are working as intended - they just have no resistance to push against
    I can move the clutch arm (that the slave pushes on) with my fingers about 20mm without resistance (cant budge the rolla's one at all) so im thinking rookie & ky may be onto some sort of 'inside the bellhousing' problem.
    the clutch is effectively stuck 'on' (off?) and wont disengage.
    Ill move it to the driveway (which is level) and give it another bleed/rock in gear before giving up and dropping the subframe/engine out and binning the rest.
  8. in Croma news, i have replaced the slave cylinder with a new one ($30!) and a uno master (+ extra flexi from the uno slave) from pickapart.
    unfortunately i cant seem to get the thing bled properly despite pushing at least 3 liters of fluid though it.
    Either that or the clutch is jammed on somehow (i can move the arm on the gearbox by hand quite a bit). I dunno.
    Engine starts and runs fine, so its a bit annoying that i cant test drive it.
    Grass is getting long around it so i will move it to the driveway and give it another bleed soon, and based on that either drive it then strip it, or just skip the driving bit.
    ___
    Recent monarchy related long weekend, we went on a family holiday up to the Tutukaka coast (east of Whangarei), 3 adult sized humans + one medium sized dog + stuff for 4 days 3 nights, 2 surfboards and wetties, no worries.
    Only drama was a carb blockage (a small bug/worm in the main jet?!) about 2km from our local servo, which was easy fixed and not really the cars fault.
    Also a knock in the rear suspension was traced to (both!) top nuts on the shocks coming loose. One has worn the thread off a bit on one side, and both are missing the lock nut - WTF.
    It is using a lot of oil tho, and i pulled the plugs before leaving - #1 was very ashed up to the point of no gap, and all the others were also ashes/oiled to lesser degrees, and these were brand new before heading to Nelson.
    Smells of oil on overrun and puffs a bit of bluey smoke on startup, free revving and after idling for a while as well, all of which point towards worn valve stem guides. This is the head that came with brass sheet under the shims, so despite having new looking pistons and a rebore i also suspect worn rings. Way too many oil pressure light on oil surges (one is too many, but sump-baffles have cured this, probably a bit too late) and slowly reducing oil pressure over time also point to worn/wearing main bearings too.
    Doesnt really seem to be affecting starting, idles like a top, or performance (surprised plenty of fellow holiday makers thinking they would pass 'that overloaded old blue car' on the hills  :D )  but time to pull finger and put the NA 2L and 5 speed in which are just taking up valuable room in my too small garage.
    Anyway, pics:
  9. Yeah, two points in the last 20 years does not a trend make.
    For a fun game, try find your OS steed in the list of cars they have in the supplement.
    Im interested to see how they deal with light deisel rego costs, as when was the last time you saw ACC paying out for an 'emergency' respratory injury cause by elevated atmospheric PM10, hmmm?
    Thats right, they fucken dont (preexisting condition or repetitive injusry, not an accident) .
    ps just dont follow my van too close going uphill, suckers hahaha..hack..cough...
  10. i have a box of weber bits incl jets you are welcome to swapsies with. (on a busy nightclub one in one out basis :) )
    bring to BF tomorrow? we can play carbs.
    those jettings dont seem to out there.
    could be the mixture screw is busted, or its seat worn
    or maybe idle jets too big,
    or ???
    i have same issue on my downie and it runs best wound right in and adjust using the throttle stop. seems bung but it goes fine (mostly)
  11. Why not just piss it all off and use a microsquirt for everything??
    U MAD BRO!
    I dunno man, stop hassling me. I probably will, but all this electronic shit is new to me.
    I mean, calibrated orifices and weights on springs is pretty simple. 2x computers, 10x sensors, and 100x wires to do the same thing (but better, i know)  just doesnt seem as elegant somehow.
    OTH,
    TURBO!!!
    I got a new slave cylinder for $30, with a parts order for the dailies, but masters are like $120 if they are instock.
    So to 'save' me $98 i drove 50km round trip to PaP Takanini, spent 3/4 of a sunny Saturday in the greasy mud and got one from a wet and smelly Uno for $22.
    Hopefully next weekend should be able to test if the boost guage works on my private test track.
  12. yes, i was awake pondering this last night.
    Mircroplex (ignition) &/or Jetronic (Injection) doesnt need dizzy for signals, but does need 2 tooth crank wheel (crank position) and pulse from coil (RPM).
    However the engine does needs spark - either from dizzy (which dont fit) or some alternative - edis needs 36:1 trigger wheel (already have 2 tooth for Microplex and Jetronic in way).
    I thought maybe mounting two wheels (one front one back?) might work, but unsure of practicality
    May just copy Nick (which is a good strategy i suspect!) to keep 100% OEM management withonly packaging to worry about or go fully Link or Mega-thing or whatnot.
  13. maybe? basically need to replace the dizzy with something non-dizzy
    cam mount will clash with brake booster, there is no block mount hole (or oil pump shaft to drive it), current possition will be in firewall, and nicks solution, well i probably will mess it up.
    and hoping EDIS might be the go, if i can make it as 'dumb' as possible (no advance) as the Microplex will handle the advance.
    Essentially a dizzy but firing the sparkplugs off a crank trigger wheel instead of a rotor in a cap - maybe COPs?
    All sugestions welcomed, this fancy electronic stuff is all new to me!
    evlone said on t-124: "if its magneti marelli microplex as you say it is they are run a full 3d map of the rpm and crank sensor and vacuum and all the advance is done in the ecu same as uno turbo 130 tc etc distributor does nothing but send spark down the plug leads as it swings past "
    "microplex is full 3d map ecu decides on advance based on rpm versus crank position and engine load based on vacuum and boost"
  14. also, have a read of this, i think im gonna be busy
    124 Special croma turbo repower
    http://www.turbo124.com/forum/viewtopic.php?f=11&t=2905
    main jobs will be
    - changing the head from 'reverse flow' to normal flow, but a normal head just bolts on and the manifolds bolt on the other way :)
    - rwd bell housing bolts up, puts starter on (normal) inlet side
    - tap 1 bolt for RWD engine mounts
    - turbo/inlet/intercooler packaging
    - ignintion - dizzy issues - no boss for the block mount and booster is in th eway of cam box mount, so cant use the Digiplex initially, (unless  do what Nick did above) but probably to EDIS,  just need a new trigger wheel and the module, is a common conversion in the US.
    - injection - will use Jetrronic for now
    May use the red car as a mock up whn it comes to that point so the blue one can keep running.
  15. Got this in the mail the other day, all of it will be needed in RWD too.
    - CPS sensor
    - Dizzy cap and Rotor
    - Cam Blt and Tensioner
    my order came to $16.62 more than I paid for the car (but that included a mechanical fuel pump for the 125 and postage)
    chcked that in (apart from the cam belt and tensioner) and Ive got it running now, after a bit of connector drama.
    went to pickapart and stole some injectors (704 vs 401 so a bit leaner, but not sat for 10 years) from a BMW and a bunch of bosch connectors as well as the Fuel Injection is LE-Jetronic controlled + a Marelli Digiplex (with a vacuum line input!) to handle ignition so both can be standalone.
    CPS connector swapped over - now have signal to the injectors! woot-woot!
    pop in the bmw ones and she fired up almost straight away!
    starts first pop now, and revs out, but i dont know if the turbo works as it wont boost without load.
    Which brings me to the next issue is the clutch hydraulics, so i can take it for a test boooost on my private test track.
    It seems the master and slave cylinders are jammed in thier bores,
    Dont really want to spend $200 on new parts just to bin them after 10km, but i also want to take this for a drive to motivate me to put the engine in the 125.
    Anyone got Fiat croma/Lancia thema/Alfa 164  or Uno clutch master and/or slave cylinders kicking around  in the shed?
    Here it is in the slopy corner of doom having some wagon time till i get clutch bits to test drive it, then/or drag it onto the driveway to drop the engine out.:
    ______
    Nothing much to report on the 125, been distracted by other stuff and the croma has been sucking up car time.
    However did get it out it for the first drive since geeting back from Nelson the other night to a BBQ and then to Burger Fuel..
    Before that I got a new mechanical fuel pump  in with the Croma parts order, and in, wow, heaps better, fuel pressure & flow must have improved considerably, bowl in regulator was actually getting drained before on hard runs!
    old one had a slightly different angle on the 'foot' that would have made about 5mm difference at the aux shaft lobe which is only 10mm or so eccentric - i think it was probably pumping less than 1/2 what it was meant to.
    I also sorted the steering column switches and swapped the steering wheel for a slighty larger one i got from an op shop (ex-subaru momo), which made a bit of differnce to turning effort.
    Can also see all the guages :!:  and the steering wheel offset (which is a bit much the other way now ( :rolleyes:)
    Must get it out more!
