Posts posted by wickmyster
I am on bimmersport atm XD. My engine has done 297000k on the original chain etc. Will put a new tensioner on soon to see if it stops the rattle and I will pull of the sump to see if there is anything suspicious and the rocker cover to see what the sprockets are like.
I am wanting to do my camchain guide sprockets etc on the e36 318is but where can I get them for under $700?????
As per title....Do mk2 escort two door back seats fit into a mk1 two door??
This car does not ahve a crank angle sensor...will check of rotor is spining in dizzy next..and the the leads.
HELP...my 1993 Celica died while driving it (Suddenly), there is no spark, I have replaced the coil and the alarm relay. There is power getting to the coil. Any ideas????
Here is a pic of the actual car I am wanting to get the diff from.
http://www.freeimagehosting.net/5f5wv
Whichdiff is that?
Do mk1 capri diff heads fit into escort diff housings?
I am looking at a mk1 capri factory 1600OHC diff head as I have heard they fit into escort houseing and are a lot stronger!!
Any one have a clue?
Is a 2.3 cortina V6 solex a good carb upgrade for a 2L pinto? Does it bolt onto the manifld, if not , how hard would it be to fit?
Able to be fitted into a mk1 though? Even as a temporary fix?
Does anyone know if Mk2 escort headlights and buckets fit into a mk1.
I am in need of headlights and buckets asap, but have only found mk2 ones, will the buckets bolt in or will I have to do some modding??
Hmm, wish I could just trim the bottom third off the standard lights, Might get another set ad have a play around...
I have just purchased a Mk1 escort wagon and I am in the process of getting it back on the road.
But.....
Mk1 Escort Estate tail lights are not pretty, so I was thinking of using Escort panel van tail lights.
What do you guys think? Anyone keen to photo shop some in for me??
Cheers, I used a mint set of 2nd hand followers and the cam itself was mint but well used. So hopefully they have all weathered well It is now the ex-girlfriends car and if it doesn't last I'll be happy, she might sell it back to me... fingers crossed!!! I miss that eski
I'm not liking the tail lights that ended u on the production car, give me the 2ns concept tail lights any day.
I have an escort shell which I want to make into a quick street car. I have a mate who had put a SR20de into his mk1, but is running carbs and a modded dizzy.
I would like to drop a vct SR20 into my beast, but run the fuel injection. How tricky would it be to trick the factory ECU to get it to run in my eski?
I have driven a NA s15 and is is ridiculously cheap to tun, so would like the same in my eski.
Has anyone done a vct sr20 conversion in to their oldschool before?
I am just wondering what I should turn my boost down to in my jza70 supra (Auto atm ..) to get it running as economically as possible saving gas and fines I am going to get an electronic boost controller with a switch to flick between standard boost and low boost, so I have the power when want it.
Is there a formula to follow, I want my boost setting to equal about a N/A with 11:1 compression ratio, so to make about 200ph down from the 280+
It is my everyday driver, and being an auto, it is hard to stop it coming into boost. So please no comments about self control.
Ok, I have asked guy to measure.
I was looking at this
http://www.trademe.co.nz/motors/car-par ... 614571.htm
for the light brackets
Does anyone know if ZF Fairlane headlight brackets work for converting a standard Xa into a twin headlight (GT replica).
I know the ZF has two headlights the same size and the Xa has two different size driving lights, but are the spacings the same.
I do not have a XA GT grill yet, so I cant measure the distance between to compare.
And ideas??
This vvti 2J does not need the key etc, it is an earlier vvti one that has been running in a different car before.
What did you drop the 1J into????
Did you use wiring diagrams or just nut it out??
LOL still for sale, just know someone who is keen, but 1st in first served . He just wantes to know what is involved/ if it is worth the while etc..
PM me if you are keen on the motor, trademe has taken ebough of my $$$ already in suscess fees!!!
How hard would it be to get a vvti 2jz-ge running in an old coon auto or manual?
I have the motor here with full enginebay loom from a gs300 and an altezza one plus airflow meter and auto ecu etc...
What is the bare basics I need to get it running???
Any info links etc would be great!!!
I have searched for info but not come up with much...so I asked on trademe
"Are the Gen 2 D2s a lot better than the gen 1? wickmyster (92 ) 9:45 pm, Mon 23 May
yes there really dont leak anymore they use japanese seals now, and the design of the internals are a lot different and the shock shafts are bigger. These are comparable honestly with tein coilovers now, the quality really is top."
Are they worth buying new now for sub $1500??
or am i better going a decent spring/shock combo for a similar price?
I want the occasional track day capability...
Ahh, all good, there are some on trademe for ot to bad price.
Where to get BMW m42 camchain kit ?
in Tech Talk
yup, i have found a second hand engine with 120,000ks that has over heated. waiting to hear back from guy though....
